Oil change interval
Old Aug 12, 2009 | 02:12 AM
c3_guy's Avatar
c3_guy
Default Oil change interval
What is a good oil change interval for our cars? On my daily driver I change oil every 3000 miles. My C3 only gets driven 500 to 1000 miles a year. I have been changing it every season, am I wasting money?
Old Aug 12, 2009 | 03:12 AM
baxsom's Avatar
baxsom
you have definitely asked a loaded question. there are some that swear that their oil will go bad just sitting there in the oil pan and cause their motor to fall apart if its left in longer than 2 weeks.
others will leave it in for wayyyyy too long.
here is the thing. do an oil change. send in a sample of the oil to be tested. there are a multitude of labs out there that will test your oil.
they will tell you whether or not that oil is still good. their simple test will tell you if the oil is still working to protect your engine and recommend a longer or shorter oil change interval. your oil is either protecting your engine or its not. the test will tell you one way or another.
there are some that will say that they can tell if oil is bad by the color.
me i will put my faith in scientific measurement.
there are some that will say that oil will go acidic if it is left sitting in a crankcase too long.
now bring on the controversy
Old Aug 12, 2009 | 07:55 AM
c3_guy's Avatar
c3_guy
In my case, I have a stock L-82 motor with a 4 speed. While I do like to leave stop lights fast, I tend to baby the car.
I'm up for a good debate, this one has got to be more interesting than trying to justify insurance fraud.
Old Aug 12, 2009 | 08:30 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Once a year before winter hibernation is a schedule I have followed for many years. I put more miles on than you but that should work for you as well. If the car is sitting and not being short-started the oil will not deteriorate and you're good to go in the Spring.
Old Aug 12, 2009 | 08:34 AM
Paul L's Avatar
Paul L
I change the oil/filter in October just prior to the winter storage season (dead storage, November to April, no starts). Thus any acidic byproducts of combustion are removed. And it is ready to go for another season in April. About 1,200 miles per mile. An oil change is cheap insurance.
gerry72's Avatar
gerry72
I change oil once a year. But as baxsom wrote, if you want an answer based upon the evidence and not opinion, pay about $30 and have your oil analyzed.
Besides, there would be no answer that would give you anything to go on. Some people have issues (rich fuel washdown, coolant leaks, temperature fluctuations...) that can change the outcome and the answer.
Old Aug 12, 2009 | 08:38 AM
3JsVette's Avatar
3JsVette
When you do drive the car do you go around the block or take it for a ride long enough to bring everything up to operating temperature? Do you start the car up in between just to see if it starts and let it run for a few minutes and shut it down? If that's not the case I would say change the oil before the start of the driving season - use GOOD oil (synthetic) and a high quality oil filter - and I think your car should be fine.
Old Aug 12, 2009 | 08:40 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
You pose a very good question......When I was younger and was driving (back in the 1970's), it was generally taught that oil changes should be every 6,000 miles. And we did that.... with no apparent problems. Now it's taught "every 3,000 miles for an oil change...Why is that? Is it a conspiracy from the oil companies? from the oil filter manufacturers?
"There is no government conspiracy....because it's all true."
Old Aug 12, 2009 | 08:56 AM
7t5's Avatar
7t5
St. Jude Donor '14
Just the opposite, in my opinion. 3,000 used to be the standard. Now look in any owners manual and that length has been extended out to 7,000 or more for some cars. 3,000 with modern oil is a waste ON NEW CARS. On old cars, who knows. I never change oil in my 4.8 Silverado until the light comes on to tell me it is time. Ranges from 3,500 to 5,500depending on how I have driven it. 125,000 miles on the odometer and it doesn't have any issues.
Old Aug 12, 2009 | 10:25 AM
FB007's Avatar
FB007
Sure. An oil change is cheaper than testing. No brainer there. Oil testing is for ships and such that takes GALLONS and GALLONS of oil to change. Not, a 5 qt Chevy.
Old Aug 12, 2009 | 11:38 AM
7t5's Avatar
7t5
St. Jude Donor '14
Not necessarily true. I could see it being worth a one time expense to see where your engine is in terms of wear. There used to be a company that would take your old filter and cut it open to determine what contaminants are in it. Could be well worth the money from a diagnostic point of view.
Old Aug 12, 2009 | 12:20 PM
C3 4ME's Avatar
C3 4ME
as several have mentioned, I change mine once a year before the winter, although mine doesn't get stored for the winter. It might be longer periods between drives in the winter, but I will take it out on a sunny day. I put 2-3K a year on mine.
Old Aug 12, 2009 | 12:33 PM
stock76's Avatar
stock76
I change the Vette once a year (synthetic) even though it usually only has a thousand miles or less on the odometer. Yes, I know that is overkill but its only a few dollars extra since I do it myself.
My daily drivers used to get changed every three thousand miles but I have upped that to 4500 to 5000 miles now.
Old Aug 12, 2009 | 12:43 PM
FB007's Avatar
FB007
So, your engine runs perfect, the leak down test is good, and the oil tests say different. What would you do? Tear it down, or run it till it dies? It's a waste of money. BUT, it's yours. Do whatever you like.
Old Aug 12, 2009 | 03:25 PM
7t5's Avatar
7t5
St. Jude Donor '14
It could tell you if the bearings are wearing, for instance. Maybe save you from serious engine damage by catching a bearing before it spins. I don't know, maybe find small anti freeze leaks or really high levels of fuel or???
And, I think it is not that much. I saw a website that said from 10- 30bucks.
I wouldn't do it, I suppose. But, I can understand why it could be a good thing.
In a nutshell, it would be strictly preventive maintenance, catching little problems before they get to be big problems.
Old Aug 12, 2009 | 10:19 PM
dannyman's Avatar
dannyman
Good question!
There is no 'one answer' to this one!
I have two daily drivers at my house; and don't maintain them with the same intervals. One gets abused, the other pampered! The abused one gets more maintenance because I want to keep abusing it!
The pampered one gets attention on a reduced level, because that's what it needs.
You have to treat your car to the degree that it requires. If you change your oil once a year and it leaves the crankcase like molasses, in density and color; you may consider changing twice or more in a year. If you flood the engine every time you start the engine you may consider changing the oil every time you start the car!
You need to monitor your situation and determine what you consider to be a reasonable level of maintenance. Every vehicle is different. If you are dealing with a fresh rebuild with excellent tune; you could probably get away with less frequency. If dealing with an original high mileage neglected motor, the oil change change frequency should be considerably greater; unless you are attempting to speed up the rebuild process of the engine.
Old Aug 27, 2009 | 10:24 AM
7t5's Avatar
7t5
St. Jude Donor '14
I wanted to resurrect this thread to put in a link for oil testing. Basically says what i said earlier, but gives the name of a company that will test oil for about 20 bucks.
http://blogs.carcraft.com/6568035/ed...oil/index.html
To Oil change interval
Old Aug 27, 2009 | 12:03 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
My car comes to me in a dream, and politely asks me if I would change her oil now. I usually get the oil and filter the next day. I think this is the only scientific way to do it, so I have stuck with it over the years.
More seriously, I change mine every 3000 miles or once a year, whichever comes first. Regretably, this year it was the year that came first.
Although I agree that if you were to drive your car 500 miles per year, the BEST time to change it would be before winter storage, but I think some common sense needs to be applied here. If, for whatever reason, you only had 100 miles on the oil when it got to be time to store, I don't think you need to change it out of some fear of "acidic buildup" in your oil. On the other hand, if it got to be storage time and I had 2000 miles on the oil, I would probably change it myself just to avoid leaving all that dirt and what-not sitting in my engine for 4-5 months.
I think the much more important issue is using a high quality oil, and not what is on sale this week at Walmart.
Old Aug 27, 2009 | 05:35 PM
BobC9's Avatar
BobC9
Looking at other forums, there is alot of different numbers floating around.
I have always changed the oil in a daily driver at 3000 to 4000 miles and have never had any problems. My wifes BMW runs synthetic and under the warranty, the dealer will change the oil every year regardless of mileage.
So when I get the vette driveable again, I will change every 3000 to 4000 miles. If I'm going to store it over the winter I will go with those suggesting changing the oil before the car is put up for the winter.
Old Aug 27, 2009 | 08:14 PM
7T1vette's Avatar
7T1vette
Dino oil changed every 3000 miles or every 12 months [whichever comes first] is a safe way to operate. Also, changing it just before periods of minimal use is a good practice. If you use synthetic oil, changing the filter at 3000 mile intervals [use WIX or other good quality filters] and changing oil at 6000...or even 9000 miles should be equally good. Synthetics don't degrade the same as dino oil, and they have a higher tolerance to heat so they will protect for a longer period of time.
