Overheat -- again...any help?
Old Aug 13, 2009 | 02:11 PM
TyCor's Avatar
TyCor
Default Overheat -- again...any help?
engine overheated last week. I flushed and refilled. drove the car at about 60 mph for 20 minutes....then engine began venting fluid into expansion tank again. because the car ran withour a problem for a good 20 minutes, and then began overheating...I think the thermostate is good...what else could it be...the radiatorand all the hoses are in good shape...how can I tell if the water pump is going bad?
Old Aug 13, 2009 | 02:24 PM
randyredleg's Avatar
randyredleg
Was timing discussed in your previous thread? If too retarded it will run hot.
Old Aug 13, 2009 | 02:35 PM
SIXFOOTER's Avatar
SIXFOOTER
About the only a waterpump will make you over heat is if the impeller came off, and thats not very likely, I would look other places first.
1. is the air dam in place and in good shape
2. are the seals for the radiator to mount and shroud in place? and on top of the rad to hood?
3. Lower hose has the spring in it?
4. What fan do you have? Is the fan clutch good?
5. What radiator cap?
6. What temp did it get to?
7. What is your base timing and all in timing set to?
Most of the time it is come combination of the above that is the problem.
Does it get hot when on the highway or in traffic? What is "HOT"
Old Aug 13, 2009 | 02:41 PM
okgsds's Avatar
okgsds
I have a thread going HERE that talks about over heating and timing etc.
Old Aug 13, 2009 | 04:08 PM
TyCor's Avatar
TyCor
i thought I would add one more thing...
when on the highway at 60...the car runs around 170 deg...it was only at idle when I stopped at the traffic light that the fluid began venting overboard and the temp began to rise. just so I am clear, the radiator had basically vented all of the fluid overboard, and then the temp began to increase.
Old Aug 13, 2009 | 04:41 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Generally speaking, if she runs OK at freeway speeds, your radiator is OK, and your speed allows for plenty of air flow across radiator. In traffic, air flow is dependent on your fan, clutch and ducting. I use an ac fan (7 blade I think) and a thermal clutch.
Old Aug 13, 2009 | 06:27 PM
SH-60B's Avatar
SH-60B
^^X2. Check the fan clutch.
Old Aug 13, 2009 | 07:42 PM
TyCor's Avatar
TyCor
how can I tell if the fan clutch is going...what am I looking for?
Old Aug 13, 2009 | 07:50 PM
KB9GKC's Avatar
KB9GKC
Hello,
Take a look at your heat riser valve on your exhaust system. It should be open when the car is warmed up. If it is not operating correctly it would hold back exhaust and cause the car to overheat when idling.
The heat riser opens with a bi-metal spring and sometimes gets hung up when old/rusty.
Good Luck,
Douglas in Green Bay
Old Aug 13, 2009 | 08:04 PM
TyCor's Avatar
TyCor
The car has headers and side-pipes...te vaccum controlled valve that shuts off the flow to the heater core has been removed...what other valve is there?
Old Aug 13, 2009 | 09:44 PM
SIXFOOTER's Avatar
SIXFOOTER
With the engine warmed up, running and hood up. Watch the fan while you turn off the key, if the fan turnes more that 1/2 to 1 turn the clutch is bad.
Still need to verify seals in place
Old Aug 13, 2009 | 10:34 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Grab the fan and wiggle it. If there is any slop in the clutch, it's shot. I got one (Flex a Lite) from Summit, cuz the Chevy one is big bucks...
Old Aug 15, 2009 | 10:49 AM
TyCor's Avatar
TyCor
Can someone explain where the radiator seals are again, I looked, but don't know what I am looking for.
Old Aug 15, 2009 | 01:48 PM
falconview's Avatar
falconview
Did all this start happening after the flush? First off don't guess at the T-stat if your not sure. For the price of one and the damage a bad one can do just change it.
With engine hot run you hand across the entire surface of the rad especialy near the lower rad hose, start at the top near the upper rad hose which should be the hottest point and feel for soft or flkinging fins...if you find cold spots on the rad or like warm spots its your rad. There shouldn't be much of a variation between the hottest and coldest spot, maybe 10C, you can also remove the rad send it to a rad shop and have them check it and eliminate that variable.
Old Aug 15, 2009 | 04:46 PM
dstaley's Avatar
dstaley
If it doesn't overheat on the highway, you have enough radiator capacity and your thermostat are likely OK.
Since you are mostly having trouble at low speed, the fan clutch and shroud are the most likely culprits. If your fan shroud is in place (not missing) and is in good repair (no big gaping holes), consider replacing the fan clutch. They're about $50 at the local parts store and are critically important to keeping it cool during "city" stoplight-to-stoplight driving.
Old Aug 15, 2009 | 07:44 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Radiator seals are around the fan shroud.
You can buy a complete set from our vendors but the fan shroud will have to come out as some of the original seals were stapled onto it. I recall the fan needs to come off and the radiator core support loosened up. This means draining the radiator and disconnecting the radiator hoses too. I didn't use staples to attach my new seals but just used 3M weatherstrip adhesive - seems to hold OK.
I know this sounds like a lot of work but after nearly 30 years the old foam seals are mostly gone. And the seals do make a difference and are important to good cooling.
Hopes this helps,
cardo0
Old Aug 15, 2009 | 11:25 PM
nelsoncomp's Avatar
nelsoncomp
5th Gear
Default What year
What year vette do you have? If you have an 81 or 82 with the extra electric fan we sell a part to help your car run 25 degrees cooler on in town driving. I use it on my 81 and its perfect no air dam even required.
NelsonComp
Old Aug 16, 2009 | 12:46 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Could be your timing, or it could be your radiator cap.
My 454 ran about 190 on the highway, but bumped up to about 220 while idling in traffic, or cruising. The thermostat was opening at 14 PSI and peeing on the ground when I stopped. I am not sure if it ever got over 240. I checked the thermostat on the stove with a candy thermometer, and it opened up at 165 so I put it back in. I put a 16 to 18 PSI cap on the motor, added an overflow tank, and retarded the base timing a bit and increased the mechanical advance to compensate. These three items cooled off the motor while cruising a good bit. Now it rarely goes over 210. I bought some water wetter, but never put it in. Did the Hot Rod Power Tour with no issues.
To Overheat -- again...any help?
