1973 Corvette fuel filter
Old Aug 14, 2009 | 03:31 PM
eb106's Avatar
eb106
4th Gear
Default 1973 Corvette fuel filter
i have a 1973 corvette that keeps dying on me. the car was not getting enough gas, so i replaced the fuel pump. that didn't help much, and the gas tank is rusted, so i blew air back through the gas line and blew the sock off. that helped a little, but now the car doesn't run for very long. i was wondering if there is another fuel filter under the car that could be plugged up? or if not, does anyone have any ideas what could be wrong with the car?
Old Aug 14, 2009 | 03:34 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If your car still has a Quadrajet, the filter is in the carb where the fuel lines goes in. Remove the 5/8 fuel line fitting and then use a 1" wrench to remove the filter housing.
Old Aug 16, 2009 | 09:34 PM
7t3shark's Avatar
7t3shark
Be sure to hold the big nut while you loosen the flare nut on the gas line so you don't twist the line.
Old Aug 16, 2009 | 10:31 PM
eb106's Avatar
eb106
4th Gear
alrighty then, thanks
To 1973 Corvette fuel filter
