Here's a good one
Old Aug 14, 2009 | 04:30 PM
Sho'nuff's Avatar
Sho'nuff
Default Here's a good one
Why is my #2 cylinder not firing all the time? new parts from module to the plugs. Same compression as all other cylinders. can hear some sputtering out exhaust on that bank. Can a valve be sticking, burnt or a bad lifter??
Old Aug 14, 2009 | 05:30 PM
larryg3's Avatar
larryg3
i am no expert but it sounds like an issue with the valves
Old Aug 14, 2009 | 05:40 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Weak valve spring?
Old Aug 14, 2009 | 05:42 PM
dburgjohn's Avatar
dburgjohn
you say the compression is the same (I assume that also means good). check the inside of the distributor cap and see if there is a line going between terminals. This is a sign that the spark is not going to the right plug at the right time. What does the plug on that cyl look like if you remove it?
Old Aug 14, 2009 | 05:45 PM
Artsvette73's Avatar
Artsvette73
Not to take this the wrong way. But just because the parts are new don't mean squat anymore. I chased around the same thing it was a brand new cap that was no good on one cylinder.
Old Aug 14, 2009 | 06:17 PM
Sho'nuff's Avatar
Sho'nuff
Plug is dirty, wet. The others are light brown as they should be. I am kinda leaning towards the valve spring or was wondering about a bad lifter. Dont hear of too many burnt valves often. The cap is new and i did look at the terminals. A mechanic had it on one of those old Sun diagnostic machines and said it all looks good to him.
Old Aug 14, 2009 | 06:55 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
he should have seen a dead cyl then.
Old Aug 14, 2009 | 07:10 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Is this a new rebuild?
Any major work done?
just started?
if the plug is wet, rich, running cold.
Old Aug 14, 2009 | 08:25 PM
OMF's Avatar
OMF
bad plug possibly....even though it works fine out in the open air they will sometimes break down under pressure. I've seen this twice before.
Old Aug 14, 2009 | 10:17 PM
7T1vette's Avatar
7T1vette
Bad plug...bad wire...spark signal being shorted somewhere. Swap plugs with another cylinder and swap wires with a different cylinder. Run it a bit and see which cylinder has a problem then. (Don't be surprised if you no longer have a problem, either.)
Old Aug 17, 2009 | 11:16 AM
Sho'nuff's Avatar
Sho'nuff
Held engine at 1/4 throttle and slowly dumped a qt. of Marvel Mystery oil down its throat. Engine is running much better but still has a small miss. Will change out #2 plug next.
Old Aug 17, 2009 | 12:06 PM
joewill's Avatar
joewill
does it misfire under load? yes do the above suggestions, but if you have good compression then who knows.. Idle circuit on the carb may be mis adjusted if it runs fine under load... a little misfire is OK.. if your mechanic had it on a scope and saw nothing then do a little idle tuning then forget about it... did you check for vacumm leak?
Old Aug 17, 2009 | 12:50 PM
Sho'nuff's Avatar
Sho'nuff
Vacuum is 17hg. Slight 1/2in. swing both ways every 15 seconds or so. Carb. is new rebuild. It was doing this before i changed carbs. Heavy load is ok, the main miss is at steady speeds and a slow increase in speed. its ok when you drop your foot in it. At steady speed, it felt like it was dropping a cylinder. I'm assuming a valve sticking now. Will do more fuel additives to see if it helps out. Compression is so-so 85lbs cranking. low by my standards.
Old Aug 17, 2009 | 03:24 PM
0Paul Ruggeri
Former Vendor
85 is low. What are the other cylinders at?
Old Aug 17, 2009 | 03:40 PM
Sho'nuff's Avatar
Sho'nuff
All are about the same. I just wonder why it has no blow-by out of valve covers.
Old Aug 17, 2009 | 05:49 PM
dburgjohn's Avatar
dburgjohn
Default old school
we had a trick when a single plug was messing up or hunting for which was messing up. With engine running pull wire at distributor and move it back to make the spark jump (which makes it hotter). Sometimes it will clear the problem. The engine should stumble as you move it to far away. If not, that cyl is not hitting.
P.S. hold the wire tight, a loose grip will knock the crap out of you
To Here's a good one
