Rear differential temp
Old Aug 15, 2009 | 04:24 PM
72-454's Avatar
72-454
Default Rear differential temp
How warm does a rear differential usually get?
I changed gears on mine and have the feeling it getīs little warm, however didnīt check temperature before the swap.
Old Aug 15, 2009 | 05:01 PM
GTR1999's Avatar
GTR1999
Diff's run hot, if you have new gears be sure to follow proper break in procedure or you'll toast them.
Old Aug 15, 2009 | 05:14 PM
garretttpe's Avatar
garretttpe
Default differential shimming
Can some tell me how to properly shim the pinion gear on a 1980 Dana 44??
thanks
Larry
Old Aug 15, 2009 | 05:17 PM
GTR1999's Avatar
GTR1999
Send you a PM link to my threads on rebuilding
To Rear differential temp
