Bolt On Horsepower
Old Aug 15, 2009 | 09:42 PM
falconview's Avatar
falconview
Default Bolt On Horsepower
Anyone got any suggestions for some cheap bolton ponies for my L48? Will be doing it right next year just looking for some cheao spead.
I'm thinking a little ignition, no headers this year will wait till I put my rebuild in. KNN filter? any suggestions or should I just wait until I yank the boat anchor out of her?
Old Aug 15, 2009 | 10:02 PM
billla's Avatar
billla
St. Jude Donor '14
Search is your friend on this topic
Headers and free-flow exhaust will be your biggest power producer - no reason to wait unless you think you're going to go to angle-plug heads.
K&N is always a good idea. Ignition upgrades produce no additional power in the most common RPM range. Don't rule out the impact of a good tune!
Old Aug 15, 2009 | 10:24 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
If your plan is as you stated, to make big changes next year, don't waste your money on tiny incease of hp now. Use that extra money for better improvements next year.
Old Aug 15, 2009 | 10:26 PM
7T1vette's Avatar
7T1vette
Bolt on the nitrous now (low shot so you don't melt the pistons); add the rest next year...but keep the nitrous.
Old Aug 16, 2009 | 01:12 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
In addition the pragmatic suggestions above, I've always felt a 3-4 degree bump in ignition timing at idle seems to give an anemic v8 a slightly improved seat-of-the-pants feel.
Old Aug 16, 2009 | 07:00 AM
jb78L-82's Avatar
jb78L-82
A good basic tuneup, spring kit for the distributor, adjustable vacuum advance canister, a K&N airfilter, and by far, the biggest bang for the buck, a complete exhaust overhaul-2.5 inch true duals, headers of some sort (full length, block huggers, shorty etc) and free flowing mufflers (dynomax ultra flos/turbos, flow masters, Monza turbos/tips, etc). If you plan on basically a street car, especially an automatic transmission one , I would stick with block hugger/shorty headers since full length headers really only have an advantage over the other headers at really high RPM which the L-48 engine is not. As a teenager, I had a totally anemic 307 V8 in a chevy Nova and put full length headers, duals, with free flowing mufflers and the change made a TREMENDOUS difference in power, still a dog but a much stronger dog! You can easily get to a stock L-82's horsepower with these changes plus you can use the exhaust when you work/change the motor later on!
Old Aug 16, 2009 | 08:33 AM
Ganey's Avatar
Ganey
Originally Posted by jb78L-82
... As a teenager, I had a totally anemic 307 V8 in a chevy Nova and put full length headers, duals, with free flowing mufflers and the change made a TREMENDOUS difference in power, still a dog but a much stronger dog! ...
It is possible to make a day & night difference.
As a teenager I bought a 307 short block for about $50 to put in a second car for an economy work car. There were a lot of witnesses & I was offered the stock 2 bl. intake for $5. so I took it. Evidently some got the idea I was going to run it!
So on the 307 test drive, I ran across a GTO that was accustomed to being beat by my Hot Rod. Seeing his opportunity to win, he went for it. Blew him away again. He was shocked but that's what he deserved- GTO picking on what he thought was a stock 2 bl. 307! He was a good sport to keep racing & losing, but he sold the GTO after that.
I never ran sto*k (a bad word to me) & did not own a 2bl. (that heavy 2bl. intake worked to prop a garage door open) so a 4 bl. that didn't miss a beat at high rpm, a solid lifter cam & 3 spd. Hurst were installed. This was a budget work car so I used what I had (no extra headers). What I called supertuning- advanced timing, recurved dist., good spark plug wires, etc. goes w/o saying.
Originally Posted by falconview
... Anyone got any suggestions for some cheap bolton ponies for my L48? ...
I'm thinking a little ignition, no headers this year will wait till I put my rebuild in. KNN filter? ...
No on K&N.
Supertuning.
Low restriction mufflers & cat. http://www.corvettefaq.com/c3/ganeyexhaust.htm
Cam as L-48 badly needs more cam.
Old Aug 16, 2009 | 11:22 AM
billla's Avatar
billla
St. Jude Donor '14
Originally Posted by Ganey
No on K&N.
Curious - why no on K&N?
I've used these exclusively for a long time, and on a 360HP 355 I saw a 14" x 4" add 4 HP over a 14" x 4" paper filter.
I hear filtration quality concerns as well - but I ran a paper sheet inside both a K&N and a quality paper filter for 3 months each and found the K&N to be pretty much perfect.
Old Aug 16, 2009 | 11:47 AM
billla's Avatar
billla
St. Jude Donor '14
Full-length headers increase both torque and HP at low- to mid-range RPM, especially the Tri-Y (Doug Thorely and copies) design.
Shorty headers generally offer litte to no power increase over the "Rams Horn" style exhaust manifolds, but give a slight bump with the "Iron Log" style exhaust manifolds.
Old Aug 16, 2009 | 12:08 PM
Ganey's Avatar
Ganey
Bill
... just looking for some cheao spead....
1 The K&N will not provide any "speed" or HP over a properly functioning stock type filter in his setup & the money would be better spent elsewhere for him.
2 I have a friend who is really into oil & oil analysis (also racing engines) "in oil analysis usually with a K&N the Fe "iron" and Si "dirt" is elevated" & "if a guy oils them up enough to filter really well, lost airflow is the result." He is not the only one who doesn't like the oil analysis results.
You may need to think about this. In general if power is increased by switching to a K&N (which can be less restrictive) then some tuning should result in the same or more power assuming the filter size is appropriate & no other restrictions.
Old Aug 16, 2009 | 12:26 PM
billla's Avatar
billla
St. Jude Donor '14
I appreciate the background on your recommendation. I reach different conclusions from my own experience, but I agree there are aspects there to consider.
Old Aug 16, 2009 | 03:16 PM
jb78L-82's Avatar
jb78L-82
Full length headers from my understanding and personal experience on various cars is that there is little to no gain in low RPM and horsepower with full length headers aiding mostly with high mid to high RPM horsepower and torque. Full length headers in fact HURT low RPM horsepower and torque over the cast iron ramhorn manifolds. No experience with the Tri Y headers you mention, though. I currently have McJack's shorty headers on my L-82 and there is a definite improvement in mid to high RPM horsepower and torque over the cast iron Ramhorn's-sorry but my personal experience differs with your comments. I added the shorty headers as a stand alone change to true 2.5 inch duals and turbo mufflers that were already on the car and the difference is very noticeable. Another example is again a stand alone addition of BBK shorty headers to my 1994 Mustang GT that already had a magnaflow dual exhaust and again the difference just adding shorty headers was very noticeable. On the Mustang GT, the car had the OEM tubular exhaust manifolds (very similiar to a shorty header but with smaller primaries) and the BBK shorty's definitely made a difference.
Old Aug 16, 2009 | 03:50 PM
billla's Avatar
billla
St. Jude Donor '14
We'll have to agree to disagree
I'll note in passing this conflicts with every dyno test I've ever seen - including my own. We could split hairs and note that below 2500 RPM there's maybe a break-even at best, but 2500 on up (I would call anything between 2500 - 4500 "midrange") long-tube headers will beat any stock manifold or shorty header. Certainly you can have a too-large header diameter which leads to poor low- and mid-range flow, and of course the gain will be more up top.
Note that this is specific to the Chevy GEN I SBC and it's weak exhaust port. Every engine is different
Old Aug 16, 2009 | 04:21 PM
terry82's Avatar
terry82
k+n great marketing .there are no fleets that use k+n filters .why because they let in more dirt .this topic has come up on this forum for years try the search lots of pro and cons .i am on ganeys side .
Old Aug 16, 2009 | 05:24 PM
jb78L-82's Avatar
jb78L-82
I agree with your points mostly and also agree that long tube headers will beat shorty's everyday in the mid to high RPM's but disagree that there is no benefit to shorty's over the ramhorns on the street. With my shorty's on both cars there is no gain in horsepower or torque (or very little) in low rpm's but my shorty's have definitely helped in the mid to high RPM versus the ramhorns, not full length headers. If you mostly run your engine in the high mid to high RPM's, full length headers beat everything but most people don't run their engines consistently in that range on the street. To me full length headers are not worth the fit issues, road clearance issues, heat issues etc for the street but they definitely are the most efficient in making horsepower and torque if that is the ultimate goal barring other concerns. Hope that explains better my point.
Old Aug 16, 2009 | 05:26 PM
billla's Avatar
billla
St. Jude Donor '14
my shorty's have definitely helped in the mid to high RPm versus the ramhorns []. Hope that explains better my point.
To Bolt On Horsepower
