Trans AM GTA wheels
Old Aug 17, 2009 | 02:56 PM
camber's Avatar
camber
Default Trans AM GTA wheels
hi guys--need your help--will Trans-AM GTA--16x8 wheels fit on my 73 -I believe they have the correct back space and bolt space--THKS
Old Aug 17, 2009 | 03:46 PM
lvrpool32's Avatar
lvrpool32
The only issue may be caliper clearance. As the brake caliper body sits further forward than the wheel mounting face on the brake rotor, you need spokes that have a slightly forward swept angle. You could always slip in a small spacer if they do hit.
Nick
Old Aug 17, 2009 | 05:04 PM
markdtn's Avatar
markdtn
I have 16x8 IROC wheels on mine. Had to use all fronts due to offset. Had to clearance the E-brake cable bracket so it didn't hit the wheel weights.
Old Aug 17, 2009 | 05:30 PM
camber's Avatar
camber
Hi NICK--THKS FOR YOUR QUICK RESPONSE--lets see if someone has actually tried these rims--I have spacers would rather not use them-- let's see what response we get--camber
To Trans AM GTA wheels
