Sidepipe + cover mounting..
Old Feb 17, 2002 | 07:58 PM
Black68Vette's Avatar
Black68Vette
Default Sidepipe + cover mounting..
I picked up a barely used set of sidepipes + unpainted fiberglass covers that had been sitting in someone's attic for years. I mounted the sidepipes fine, but am having problems with the covers. If I line the covers up with the holes in the lower body panel, it sits about 2 inches higher than the pipe. Also, I have no idea at all how the z shaped rear support bracket is supposed to mount. Anyone got some ideas for me? I'm starting to think that the mounting tabs on the pipes might have gotten bent while sitting in storage (having stuff piled on them maybe) and thats my problem. Still that doesn't help with that support bracket, I can't even guess on it.
Eric
Old Feb 17, 2002 | 09:06 PM
Pete79L82's Avatar
Pete79L82
Default Re: Sidepipe + cover mounting.. (Black68Vette)
My pipes sit below my covers also. If you get down and look close you can see them but if you are standing up you don't notice it at all. The z shape brace goes to the rear of the cover. The single hole mounts on the frame and the double hole mount to the cover. There should be a hole in the frame just rearward of the pipe mounting hole.
[Modified by Pete79L82, 7:08 PM 2/17/2002]
Old Feb 17, 2002 | 09:25 PM
VettePower's Avatar
VettePower
Default Re: Sidepipe + cover mounting.. (Pete79L82)
Another question. I too am getting ready to put on sidepipes and covers, but after looking at my front fenders I am wondering. On the passenger side it will be no trouble, as there is plenty of room for the exhaust pipe to exit. But on the drivers side, I have 2 bolts that seem to hold a bottom or cover to the vacuum tank. I would have to at least cut off 1 of these bolts in order for the exhaust pipe to exit. I have a 77. Did you run into this problem and what did you do? :flag
Old Feb 17, 2002 | 10:20 PM
Black68Vette
Default Re: Sidepipe + cover mounting.. (VettePower)
Sorry, mine is a 68 (gotta make my signature with some pics), with absolutely nothing resembling emssion control systems on it, and no vacuum tank. My car even has a different hood, so no windshield wiper pop up panel. Although I do have to say that the bend in the pipes are rather different from the left side to the right side, so it may be specifically set up to have clearance around that. One big plus I did notice is that the way the pipes route, there is no more "hot starter" syndrome. One minus is the big 3" diameter burn patch on the back of my leg :mad , from being stupid enough to drive it before I got the covers on....
Old Feb 17, 2002 | 10:37 PM
Pete79L82's Avatar
Pete79L82
Are you referring to the area right behind the front tire?
There is a splash sheild there that attaches to the bottom of the fender and the bottom of the inner fender but the bolts are suppose to go from the bottom up. All that you should see is the head of the bolt.
Old Feb 18, 2002 | 12:10 AM
Barry's70LT1's Avatar
Barry's70LT1
This page is from a 1970 AIM.
It should help explain a few things.
Old Feb 18, 2002 | 03:50 PM
VettePower's Avatar
VettePower
Yes I see the head of actually 2 bolts on the side, and they do attach to that splash shield as someone said. This is where I asking if I need to cut this section off for the exhaust pipe to make its exit. :confused:
Old Feb 18, 2002 | 03:56 PM
Black68Vette
May sound silly, but can you take a picture of it? or want me to jack mine up some and get a picture of the bottom? Cause I'm still not sure what bolts you mean, but then again mine is a 68 (and theres enough differences just going to 69). Lets hear it for one year cars...... :rolleyes:
Old Feb 18, 2002 | 03:59 PM
JCL's Avatar
JCL
VettePower. I think TRIM would be a better word. I don't think you'll have to remove this whole section anyway. JCL :cool: :cool: :chevy "Sidepipes are the way"
[Modified by JCL, 2:00 PM 2/18/2002]
Old Feb 18, 2002 | 05:19 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Sidepipe + cover mounting.. (JCL)
I think you can see in my sig how the glass covers fit against the car. the rocker moldings are completely removed. There are 4 or 5 bolts ( not wood screws like what my car had :rolleyes: that hold the covers onto the car.
The aftermarket covers don't use the z shaped bar nor the 'd' shaped piece. The screws allong the top do all the work...
As far as trimming where the pipes come out, just do what is necesary to make it work, the AIM has a pic of the trimed area but you just don't want the pipes to hit...
Edit;
Dang I thought the sig pic was more of a close up...
[Modified by 427V8, 3:19 PM 2/18/2002]
Old Feb 18, 2002 | 05:31 PM
ZD75blue's Avatar
ZD75blue
Default Re: Sidepipe + cover mounting.. (427V8)
dont know about the pipes... but in the left hand sig pig, it looks like if you drove your vette it would tear in half :jester
Old Feb 18, 2002 | 05:38 PM
VettePower's Avatar
VettePower
Edit;
Does that mean the covers lie against the pipes and if so does the heat from the pipes hurt the fiberglass or the paint on the covers? :confused: :confused:
Old Feb 18, 2002 | 06:00 PM
Black68Vette
I'd say it would have to do something, it sure did to my leg on a second's worth of contact...
"Hmm lemee take it out for a quick run to the post office even though the covers aren't mounted yet" :crazy:
Old Feb 18, 2002 | 06:11 PM
Pete79L82's Avatar
Pete79L82
Oh battlescars! Wear it PROUD like a boxer wears a black eye or a skier wears a cast! :D
Old Feb 18, 2002 | 09:08 PM
VettePower's Avatar
VettePower
Seriously guys, does the heat from the sidepipes hurt the paint on the covers? Do I need to use some speacial paint???? :bs
Old Feb 18, 2002 | 09:20 PM
Pete79L82's Avatar
Pete79L82
I just used high temp silver and black in a spray can on mine.
[Modified by Pete79L82, 7:21 PM 2/18/2002]
Old Feb 18, 2002 | 09:49 PM
VettePower's Avatar
VettePower
Has anyone tried a base coat and clearcoat? And if so, how did it hold up? :confused:
To Sidepipe + cover mounting..
Old Feb 18, 2002 | 10:14 PM
micks69's Avatar
micks69
There are insulators that go in there.
Old Feb 18, 2002 | 10:49 PM
427V8's Avatar
427V8
No the covers should not touch the pipes!
I don't think the heat will get them but I know they would rattle terribly and wear quickly!
Use spacers, bondo, fiberglass, anything to make it so when you tighten the screws the covers are held AWAY from the pipes...
snip---
Old Feb 19, 2002 | 08:10 AM
Binnie77's Avatar
Binnie77
I have base and clear on mine but I have only driven 15 miles since I put the pipes on. After the drive I tried to get some idea how hot the covers were and they were about the same temperature as the rest of the fibreglass on the car. My biggest problem is not going to be the paint damaged by heat but by the crap that gets thrown up on front of the covers from the tires.
