Cold air intake on a c3
Old Aug 18, 2009 | 09:56 PM
tabbruzz's Avatar
tabbruzz
Default Cold air intake on a c3
Has anyone added one? I see Jegs sells one with two four inch tubes that extend about 42 inches or so. Was thinking of routing them to the windshield cowl ares as some say its a good source of cold(outside) air.....Thoughts????
Old Aug 18, 2009 | 10:07 PM
CCrane65's Avatar
CCrane65
Anything that will get it away from that hot radiator air being blown back toward the air cleaner.
cc
Old Aug 18, 2009 | 10:53 PM
Z-man's Avatar
Z-man
Yes - the cowl area is a source of high pressure, but unless you have an L-88 hood, how can you pick up the air there? I'd go for an area on either side of the radiator up front.
Old Aug 19, 2009 | 01:45 AM
flynhi's Avatar
flynhi
Find a dual hose cold air intake from a late model C3
Old Aug 19, 2009 | 10:11 AM
Vette79C3's Avatar
Vette79C3
Old Aug 19, 2009 | 10:31 PM
tabbruzz's Avatar
tabbruzz
Thanks guys....
Old Aug 19, 2009 | 11:51 PM
SIXFOOTER's Avatar
SIXFOOTER
You will need the duct work that goes above the rad to make it work, Its not pretty but it does work
Old Aug 20, 2009 | 08:30 AM
Paul L's Avatar
Paul L
There is another way to do this albeit expensive. You could use 1973-74 cowl induction. You will need a hood with open grille and an air cleaner assembly.
There is a flapper on the cowl, operated by an electrical solenoid triggered by WOT at the gas pedal (a switch). Remove the flapper assembly with solenoid and you will have a constant flow of cool air to the carb through the cowl grille. It works. In fact the flow of air can be heard even at idle.
The rubber ring on the air cleaner housing seals against the hood and ensures that the cool air from the grille reaches the carb.
This is the air passageway, cowl grille to air cleaner housing.
To Cold air intake on a c3
