Dimmer Switch
Old Aug 19, 2009 | 07:01 PM
base1957's Avatar
base1957
Default Dimmer Switch
How do you check the dimmer switch on a 68 vette. Rear lights work fine, well they light and blink not as bright as i would prefer. Front lights do nto come on. The light in the dash reads as if the brights are on all the time.
Old Aug 19, 2009 | 07:03 PM
wombvette's Avatar
wombvette
Unplug it and try another.
Old Aug 19, 2009 | 07:17 PM
...Roger...'s Avatar
...Roger...
Pull the 3 wire connector off the dimmer and check the blue wire for power with the headlights on. If you have power on the blue then jumper the blue to the tan and then the green.
Old Aug 19, 2009 | 09:03 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Posted Wrong so I deleted it.
Old Aug 19, 2009 | 10:56 PM
base1957's Avatar
base1957
thanks guys
Old Aug 19, 2009 | 11:32 PM
base1957's Avatar
base1957
I check the blue wire and power to it is good. i jumped to the other two wires and no front lights. guess that means i should look elsewhere first?
any suggestions?
thanks
Old Aug 19, 2009 | 11:58 PM
...Roger...
You might have a ground missing to the front lights. Check the headlight connectors for power and then the black wires for ground.
Old Aug 20, 2009 | 12:12 AM
base1957's Avatar
base1957
checked front lights for power and nothing. did notice one of the blacks coming out of the bulb connector is split in half. will fix it next chance, also noticed there was a ground wire on the side of the radator mount intact.
Old Aug 20, 2009 | 12:17 AM
...Roger...
Now you will have to find the green and tan at the engine side of the bulkhead connector and check for power there.
Old Aug 20, 2009 | 12:20 AM
RHD '68 L89's Avatar
RHD '68 L89
Originally Posted by Willcox Corvette
The light in your dash is probably staying on from a failure in the limit switch at the headlamp assembly. They break easy and when they do the lights will stay on in the dash. Here is the switch!
http://willcoxcorvette.com/product_i...ducts_id=24163
No limit switches on a 68!
Old Aug 20, 2009 | 12:21 AM
base1957's Avatar
base1957
I will pull that box and check it saturday as ive got to work early and late tomorrow.
thanks for the guidance
Old Aug 20, 2009 | 10:05 AM
0Willcox Corvette
Former Vendor
Sorry, I missed the year on that!
To Dimmer Switch
