Engine Build for 77
Question is, I'd like to build an engine to put into the car, it has the stock 350/th350 it came with and is less than exciting to drive.
My question is tons of magazine articles are focused on huge HP numbers or super big TQ with high budgets, huge cams, or a combination of both.
What I'd like to build is a small block with a lot of torque near the bottom end where a street car lives, on a budget, that will be reliable enough to take on vacation or drive to work a couple of days a week.
Anyone got any advice on combos or setups that would fit? Magazine articles doing just that?
How much power should I be looking to make I was thinking a 400HP/450TQ car would be a lot of fun, problem is I want it to make lots of TQ right off idle which usually equates to big CI engines, I'm not interested in swapping a BBC in.
Anyway sorry for the ramble hopefully this post can get this conversation going in the right direction.
Josh
ZZ383 Crate Engine
425HP@5400RPM
460ft.lbs@4500RPM
SKU: 12498772
RETAIL: $7,357.14
YOUR PRICE: $5,228.00
http://www.crateenginedepot.com/ZZ38...72-P764C2.aspx
This will make that '77 fun to drive...
Not to mention I dont have to pony all $4500 up at one time I can spread buying parts out over a while, the play fund is somewhat diminished from the original purchase. My plan is to give the car a tune up and get it on the road where it belongs, then build this new powerplant over the course of the next year and swap it out maybe next fall/winter.
I found this article online:
http://www.superchevy.com/technical/...kit/index.html
http://www.superchevy.com/tech/sucp_...ack/index.html
http://www.superchevy.com/tech/sucp_...kit/index.html
They made 425/460 IIRC for about $3300, although I question some of the parts they used, seems like they could have picked up a better stroker kit for not a lot more money......also could have used ARP bolts etc. for a more reliable build for not a ton more cash.
First step is to determine what gears are in the car; you may find some of your budget going there.
As a starting point with your targets, I'd offer the following general configuration: Start with an 87 - 98 roller cam engine (not LT1/LT4) - the newer the better. A cast crank, hypereutectic piston 383 stroker assembly from Scat making about 9.5 CR with a warm hydraulic roller cam, hopefully reusing the existing hydraulic roller lifters. Figure on a set of decent aftermarket 180cc heads along with headers and a free-flow exhaust. The head and cam choice is really dependent on your gears.
This is going to be right in your zone; a nice, fat torque curve from 2000-4500 peaking at around 450 @ 4000 RPM and around 400 HP @ 5500 RPM. All flywheel numbers, all estimates.
Not a complete answer, but a starting point
I believe the original engine was either L-48 at about 185hp or the L-82 which was 210hp....THE ORIGINAL ENGINE !!!!
Unless the engine is a replacement, your lack of power is because you do not have the horses in the original engine......
I'm sure there are a ton of upgrades that could boost the response and increase the power with the current engine.....
I'm sure many on this forum have boosted the power on their 77 without replacing the engine and for a lot less $$$$
Good Luck
Good luck with yours!
http://www.flatlanderracing.com/scatsr-chevysbcast.html
Good Luck
