454 swap into 76
Old Dec 19, 2009 | 01:30 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Originally Posted by mydejavooo
So is there a place where you can buy a bracket kit, or do you have to piece it all together?
Here is a good start - http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Dec 19, 2009 | 01:59 PM
mydejavooo's Avatar
mydejavooo
Originally Posted by DRIVESHAFT
Thank you!!
Old Dec 19, 2009 | 05:23 PM
TJP440's Avatar
TJP440
Don't overlook the pulleys as they are BB vette only and I would'nt reccomend trying to get around it the cheap way, unless of course you like overheating and frame clearance issues.
Old Dec 19, 2009 | 05:27 PM
mydejavooo's Avatar
mydejavooo
Sounds like they must use a smaller diameter crank pulley??
Old Dec 19, 2009 | 06:41 PM
TJP440's Avatar
TJP440
Correct for fame clearance. They then changed the other pulleys as well to keep the ratios right. Not cheap, but money well spent for a trouble free conversion
Old Dec 20, 2009 | 03:33 PM
Rich's'78's Avatar
Rich's'78
I suspect you will also need a better rad and fan setup.
