Is it really necessary to remove the hood in order to remove the radiator?
I looked in the service manual and of course it did not say anything about removing the hood. I rather not but I suppose that removing the hood will give you more room to remove the radiator.
Yes it will only take a second and save you a lot of time in the long run. Are you replacing you radiator support or is it good? I just remove my radiator 3 days ago. My advice is watch out for one major thing.... getting carried away. My project started out as only the radiator, the support, and water pump. Now I have removed the A/C, power steering, headers, condenser and going to lift the engine to paint and clean up the engine bay. I figure I don’t ever this much room to work so might as well do it all at once. Let me know if you have any question when replacing the radiator.
I completely agree.
I don't agree that "it will just take a second"...and lining it up when re-installing is quite the PIA, requires a helper or two, but in the end you will be glad you removed it. Yep.
I removed mine with the hood on by myself and yes, it would have been easier with 2 people. Put some cardboard between the radiator and fan shroud to keep from damaging the radiator.
If you have A/C, you have less room to lean your core support forward so removing the hood will make life a lot easier.
It's not bad. Take a drill and drill a pilot hole into each bracket so you can realign them later then take an awl and scratch around the top and inside edge of the bracket. There is a lot of adjustment in each direction so the lines will help make sure both planes are aligned.
You can omit drilling the pilot holes but it makes things easier.
In any case, with the hood out of the way you will have plenty of room to lean the core support forward. This is especially helpful in getting the shroud out. Plus things drop into place more or less when you go to put it back together.
Save yourself a lot of time and effort.
I have had mine out 5 times over the last 2 months and let me tell you you don't want to do that if you don't have to.
Before touching the hood bolts, mark the hinge locations, either scratch into the glass around the hinge on two sides, OR, use a dab of paint in that area so you can find the exact location of the hinge plate when reassembling......
cc
This is true, but if you don't have A/C, then I don't think it's necessary at all. The hard part is getting the shroud out. Do yourself a BIG favor and place card board between the radiator shroud. Your fins will thank you!
I unbolted my rad core support on the side (6 bolts) but left the bottom two in place, but loose. I then leaned the core support, rad and shroud up and pulled like hell! I found rotating the shroud 180° then pulling it out helped a lot. Once the shroud is out, just undo the radiator top brackets and slide her out.
I am thinking about replacing the stock radiator I have in my car for a better quality aluminum one and from all my reading I would remove the hood and just mark the bracket locations before removing it. I will use a wax pencil or crayon probably so I can remove it easily after I replace it all.
You can also use tape on 2 sides. That will get you as close as possible when you put it back together. Markers, crayons or pencils tend to have too wide a point to get right next to the hinge.
Thanks everyone, that is what I thought in regards of removing the hood. I have removed and installed the hood by myself when I replaced the radiator back in 2002 while doing my engine build. I also removed and installed the hood by myself this past June when I removed the condensor. My radiator core support is in good shape. (I used Por 15 on it when I replaced the radiator back then. True it would would be easier to remove and install if you have a helper. I can remove and install the hood by myself. I'm just being lazy which is why I asked the question. Guess I will remove it.
I did not remove the hood, but it may be easier for you as your 79 may be different that my 74.
PG.
In respect to your step #6, where are these 2 "top radiator brackets" located on a 75 coupe?
I'll be darned if I can locate them and are they also known as the upper radiator support panel? Also. where are the bolts located to remove these brackets?
They are the brackets at the upper corners and on top of the radiator. There is a flat plate with two holes which bolts to the reverse side of the radiator frame; an upside-down "U" channel is attached to the bracket and those fit over the top of the radiator to retain it. If you see the two bolt holes on each side of the rad frame, but nothing is bolted there, someone has previously removed those radiator retaining brackets.
ok, after reviewing the diagram I have all the bolts and nuts removed, but it still feels like something is holding it in secured and I can't figure out what may cause this??
Can anyone tell me if the A/C radiator must be removed with the coolant radiator in the removal procedure?
If you have an automatic tranny, there are two tranny oil cooling lines that are connected to the side tank on the radiator. Those need to be removed (back-side of the right side tank) and any tranny oil allowed to drain out before you can remove the radiator. It could also have some old seals that are stuck to surfaces. You do not need to remove the A/C condenser [in front of the radiator]; but you can unbolt it from the rad frame and tilt it forward to ease the removal of the radiator.
