Where can I find a BB water pump rebuild kit ?
Any instruction sheet available how to do this ?
Reason is for not to scrap a date correct pump.
Rgds. Günther
I wonder if you could just buy a reman pump,. gut it and put your old parts back in it, and the new parts in yours, then return the 'new' pump for the core?
I got told that everything is pressed in.
By dismantling a pressed together pump , one might damage the seals, bearings etc.
I really prefer getting a rebuild kit if available.
If You still want to do it yourself You don't need any Kit at all. Just go to any Bearing House in whatever City Your in and they can provide You with a replacemet Bearing and Seal. They probably have it on the Shelf. This way You can also control what Brand Name goe's into Your Pump and not whatever is the Cheapest that the rebuilders are useing this week. Any major Autoparts Store should be able to do the same. Only problem is You will probably have to disasemble it to get the Bearing and Seal Number first. The Howard Steward sounds like a good Option.
