Which Suspension Stake kit???
Old Jan 12, 2010 | 08:15 PM
AutopiaDR's Avatar
AutopiaDR
8th Gear
Default Which Suspension Stage kit???
Hello to all
Im doing a resto-mod on my C3 and i wish to get advice on which of the Supension kits available come highly recommended or if you have a modern suspension kit on your C3 that gives you a great ride while cruising and good handling then i want to hear from you.
Other things im interested are how much should i expect to pay and which kits have gotten highest customer ratings. Thanks in advance for your cooperation.
PD: Does anyone know if the rally wheels in bigger size (17,18,19) are available?
Old Jan 13, 2010 | 11:06 AM
AutopiaDR's Avatar
AutopiaDR
8th Gear
C'mon guys Im new here. I need some help on the questions asked. Sorry if its been posted before but i cant find it.
Old Jan 13, 2010 | 11:38 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
There is no one size fits all suspension kit. Different kits are designed to do different things. It's all about the end user and what you want out of the car. If you just want a cruiser than your options are much different than someone who wants more of a performance set up.
Spring rates and sway bar sizes will have different effects as well as shocks.
For front end parts, you get what you pay for. I highly recommend using Moog front end parts but you'll pay a lot more than the average kit cost.
Give me a call or check out my site. I'll be glad to help you out.
www.vansteel.com
800-418-5397
Old Jan 13, 2010 | 11:41 AM
midyearvette's Avatar
midyearvette
van steel is a great source and vendor...jmo
Old Jan 13, 2010 | 02:15 PM
AutopiaDR's Avatar
AutopiaDR
8th Gear
Thanks guys. I want a suspension for cruising that will allow great handling in the mountain roads.
Old Jan 13, 2010 | 02:19 PM
AutopiaDR's Avatar
AutopiaDR
8th Gear
My C3 is a 1970 stingray with a small block. I want in the future to swap engine to an LSx engine.
Old Jan 13, 2010 | 02:51 PM
groovyjay's Avatar
groovyjay
With the right spring rates Van Steel's coil over conversion will be great!
Old Jan 14, 2010 | 01:32 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The first thing I'd do after getting a really, really good idea of exactly what you want to accomplish (it's worth noting here that the terms "cruise" and "great handling" tend more often than not to reside on opposite ends of the comfort vs. performance spectrum in C3 land), would be to set a budget so you can prioritize in what order to approach things. Then, figure on spending about twice as much due to those budget blowing "while-I'm-at-it's". And, don't expect any upgrades, mods or kits to overcome the effects of any worn components left unaddressed. There's a fair amount to this suspension stuff, but if you take the time to do a little homework before you start spending money you'll be more likely to end up being satisfied with the results.
FWIW, I think you can get rally style wheels in 18".
Old Jan 19, 2010 | 04:03 PM
Rottenrob's Avatar
Rottenrob
Welcome to the forum!!
This company has larger rally wheels, check out the muscle car gallery for some pics of Corvettes with the bigger wheels:
http://www.wheelvintiques.com/
Van Steel has some pretty nice kits, as does Speed Direct. Vette Brakes & Performance also has a good range of kits. All three are forum sponsors, so here are their direct links:
http://www.vansteel.com/
http://www.speeddirect.com/
http://www.vbandp.com
There are other companies that also offer kits, but these three seem to be the favorites.
Robert
Old Jan 19, 2010 | 11:16 PM
AutopiaDR's Avatar
AutopiaDR
8th Gear
Thank you much for the input. Much appreciated. Going to 18's could help me address both.
Old Jan 19, 2010 | 11:22 PM
AutopiaDR's Avatar
AutopiaDR
8th Gear
Robert
thanx for the hospitality and the information.
To Which Suspension Stake kit???
