82 battery choice
Old Aug 22, 2009 | 10:28 PM
Model12's Avatar
Model12
Default 82 battery choice
All
I recently bought my second Corvette, a pretty nice 82, but I think the battery may be weak. The manual says to get a F-18 size battery.
Can anyone be more specific? My C2 has the battery in the engine compartment, not in the cabin, so I don't give it much thought. Does having one in the cabin make for special circumstances (like a maintenance free Delco or xxx brand)?
Brand/size recommendations for a C3 please? Thanks, Dave
Old Aug 23, 2009 | 03:37 AM
Peterbuilt's Avatar
Peterbuilt
Default This one works for me.
8 years ago I bought a NAPA #7578 it was still good when I replaced it 2 months ago. I just figured I would replace it before I got stuck somewhere. My car takes about 6 seconds to start if it sits for a week or more and it never failed to start my 74. The vent hoses on the 7578 are oval but the lines will fit with a little persuasion. PG.
Old Aug 23, 2009 | 07:56 AM
Ganey's Avatar
Ganey
Originally Posted by Model12
All
Yes, some C3 had special low gas batteries. Later they had maintenance free batteries. The original Delco maintenance free were very good.
Some of us use the Optima Red batteries.
I prefer dual post batteries esp. for cars that came w/ side posts.
Therefore:
1 Optima Red (expensive)
2 NAPA Select 84 34/78 because Consumer Reports rated it a Best Buy for cold weather climates. "maintenance free"
Old Aug 23, 2009 | 11:37 AM
falconview's Avatar
falconview
Personaly I prefer the Delco Maintenance free. I've put them in everything...Fords, dodge, imports and never had a problem. I have with some cheaper batteries so I stick to Delco especialy since I live in a cold weather climate... It's not to say another battery brand won't work.
Old Aug 23, 2009 | 11:56 AM
wer2xu's Avatar
wer2xu
Braille Carbon fiber lightweight battery.
B3121C
21lbs/9.5kg
1380 Pulse Cranking Amps
31 Amp/Hr Reserve
6.6” x 5.2” x 6.8"
Right Side Positive
just get an optima and be done with it...keep your batteries on a tender when not in use and they will last forever.
Lead Acid batteries do not like to be in a state of discharge.
Old Aug 24, 2009 | 06:02 AM
Model12's Avatar
Model12
For some strange reason, the Optima site doesn't list 82 Corvette as an application. Must be an oversight. They have every other model. I would assume that Corvette is ok, as these are sealed batteries (no gas leak into the cabin). Model 75/25 dual post appears to be the answer.
Correcto?
Old Aug 24, 2009 | 09:16 AM
FB007's Avatar
FB007
It's a CHEVY. Just buy whatever you would normally get for a ChEVY.
It's not a rocketship, it's a CHEVY.
Old Aug 24, 2009 | 05:46 PM
wer2xu's Avatar
wer2xu
Walk into Advanced/Napa/Autozone/O'rileys with your old battery, and ask them for a new optima.
Old Aug 24, 2009 | 10:10 PM
FB007's Avatar
FB007
How did Detroit ever survive without Optima? You MAY notice no OEM manufacturer uses them to this day. Totally unnecessary for a car.
Old Aug 25, 2009 | 12:39 AM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Bought an Optima three years ago. At first it was strong and dependable. But you guys know how these cars sit around as we fix this or that. Mine would discharge now and then, sometimes a hard to start car would drain it pretty good.
Within about 12 months, I could not depend upon it. Many sudden decisions to drive the Vette were chucked because the battery did not have enough charge to do the job.
I returned it to Costco for a full refund (on the spot), thank you Costco, bought the biggest, highest amp battery that would fit and I have never once, in the last two years, been denied a ride in the Vette. So there you go.
Old Aug 25, 2009 | 11:08 AM
Wrecked82's Avatar
Wrecked82
Plain old Interstate for me.
Old Aug 25, 2009 | 11:19 AM
Ganey's Avatar
Ganey
Detroit has shipped too many cars to count w/ smaller size batteries then they rec.!
Model12
Yes, that should work fine for basically stock.
Old Aug 25, 2009 | 04:52 PM
wer2xu's Avatar
wer2xu
why bother with steel belted radials, bias ply tires are fine.
Old Aug 25, 2009 | 05:09 PM
FB007's Avatar
FB007
Apples and Oranges.
Cars DO come with Steel Belted tires now. They do NOT come with Optimas.
Using your logic of modern improvements being judged upon their usage by automakers, Optimas fail the test.
Plain old lead acid batteries last me 5 years like a clock, then fail, and cost $100 or less.
Optimas bring nothing to the table except added cost.
Old Sep 1, 2009 | 06:10 AM
Model12's Avatar
Model12
Thanks for all helpful comments. Now I just have to figure out why my driver's seatback won't fold down to get to the dang thing.
Old Sep 1, 2009 | 01:37 PM
Dr.J's74's Avatar
Dr.J's74
of you got the bucks and no clearence issues with the top post, optima makes a damn fine batt, but dollar per calorie, per mile i would look at interstate. Napa and carquest batts are just exide with another cover on it
Old Sep 1, 2009 | 01:43 PM
Dr.J's74's Avatar
Dr.J's74
Ive got the same issue with my '74 short of pulling the seat to get an eye on the mechanizm I havent figured anything out exept reaching back w/ a 8mm wrench, and holding my mouth just right, but its doable
To 82 battery choice
Old Sep 3, 2009 | 07:34 PM
Paul L's Avatar
Paul L
OK, a 34/78 replacement. Some 1,050 cranking amps (CA) and 875 cold cranking amps (CCA). This is a battery sold by Canadian Tire here in Canada. The price is $109CDN or about $90US. It is an Exide product. Really turns the engine. Nine-year warranty pro-rated and three-year direct.
Old Sep 3, 2009 | 09:28 PM
boatdoc's Avatar
boatdoc
I'm pretty sure Napa is using Johnson Control batteries now. I was told they gave up on Excide. Johnson Control also makes Interstate.
Old Sep 3, 2009 | 11:11 PM
1969RAY's Avatar
1969RAY
>PERFECT<
