what the hell made the LS7 BB tick???
Old Aug 28, 2009 | 08:08 PM
Ironcross's Avatar
Ironcross
Originally Posted by FRSTR90
Wally since we are talkin about compression... I was curious as to what compression the second design L88's ran. If I am not mistaken, the second design L88 ran open chamber heads and the ZL1 580/620 cam.. Also, just to refresh my memory where the valves 2.19/1.88's or 2.19/1.84's
all L88`s were 12.5, and they speak of open chamber heads sometime in the 69 engines. I never found one nor was any of mine open chamber. I only know of the 2.19 and 1.88 valves and that the second design has 7/16 rod bolts and came in the 68 engines. ....I also have used the late camshaft and it is the same as the LS7 cam. The first series L88s used the 560/580 with 3/8 rod bolts and floating pins. I just took them from a crate and transplanted them where I saw fit, boat or car. Just under $1200.00 for the complete engine, and nearly as good as my A990 Hemi. But not quite....
But in my opinion the best single carb engine available....
Old Aug 28, 2009 | 08:19 PM
TimAT's Avatar
TimAT
The PO of Ol' Red and I both worked at a Chevy dealer in 71-72. He got a L-88 under warranty- it did have open chamber heads installed when it arrived, along with the 7/16 rod bolts. Even the stamped numbers along the pan rails that indicate piston size were the same.
Old Aug 28, 2009 | 08:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by 63mako
This I know. But the OP is running his simulations with small tube headers and mufflers.
I know you know that, that is why it wasn't directed at you
Old Aug 28, 2009 | 10:58 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Old Aug 29, 2009 | 07:15 AM
jeff batchelor's Avatar
jeff batchelor
http://s117.photobucket.com/albums/o...t=100_0057.flv
This is my bone stock over the counter XCH code LS-7 in my 66.
Jeff
Old Aug 29, 2009 | 08:10 AM
L88Plus's Avatar
L88Plus
Jeff, nice engine but nicer paint! When you first climbed out and the camera was aimed back at the car, it looks like chrome!!!
