Holley Carb ID
Old Aug 25, 2009 | 10:48 AM
76yellow's Avatar
76yellow
Default Holley Carb ID
I'm wondering if anyone with Holley knowledge can ID this carb for me. I've searched until I gave up on the net. On the front of the choke air hon is "list 7351" Right below that is "2894 On the base plate there is 12R-53850. On the top by one of the float bowls there are 2 numbers....8562 & 7445. Can anyone help ?
Old Aug 25, 2009 | 11:00 AM
Ganey's Avatar
Ganey
Model 4175 650 cfm
Old Aug 25, 2009 | 11:14 AM
76yellow's Avatar
76yellow
Thanks Ganey ! Can you tell me anything else about it ? What was it's application, year ? Might it be OK for my 67 396 in my 68 Vette with a 2004R ? I put it on the car but it would"nt keep running unless I kept poured gas into it. I don't really want to put a kit in it if it's not a good choice. I can have it for 50 bucks !
Old Aug 25, 2009 | 11:23 AM
gerry72's Avatar
gerry72
It doesn't have an application. It a spreadbore replacement carb from Holley. It can replace most of the spreadbore (Q-jet, Thermoquad) carbs. They run well out of the box. It would be okay for your intended application.
Old Aug 25, 2009 | 11:27 AM
76yellow's Avatar
76yellow
Thanks for helping guys. I really appreciate it. I'll see if I can find a kit by the numbers that are on it.
Old Aug 25, 2009 | 11:35 AM
Ganey's Avatar
Ganey
Originally Posted by 76yellow
Thanks Ganey ! ...
If you have a spreadbore intake & a relatively mild 396.
To Holley Carb ID
