Headlights dont work
here is the diagram
LR
Scott
you can also see the tank I am talking about
there is also somemore pictures of the car if you click the pictures
Those tubes that come out of the tank go to the relays in the middle hole. The relays then run two sets of tubes to the actuators. One for up, one for down.
1st make sure you're getting vacuum to the holding tank, turn the car on and put your thumbs over the two holes and see if they're suckings. If not, look for holes in the tank/tubing.
Then to troubleshoot the actuators, you can connect the tube from your reservoir directly to the back side of the actuator and see if that makes the headlight raise when you turn on the car. Make sure you tape off the other tube on the reservoir on the side you aren't using or it won't work regardless. If the light doesn't come up, means that either there is a hole on the actuator, or the plastic boot of the actuator needs replaced. They have them on ecklers and other shops.
To check the relays, connect the entire system up like in the diagram you have. The hoses are color coded and there are letters on the relays that correspond to the tubes. For this step it's easier if you remove the relays, there are 2 and there held in with 2 bolts each. Check to see if they have any surface rust as mine did badly, then run the system with the car on. If the lights don't go up now, and they did with the actuators, that means that there is either a hole in the relay, or that the plastic stopper has a hole in it. There is a way to fix this by taking apart the relay and gluing a rubber o-ring to the stopper giving it a better seal. Searching "relay repair" on the forums should give you the details on that one.
If you're going to be working extensively with the system you might want to consider removing the hood which gives you a lot more freedom since a lot of the headlight system is accessed from the front of the car.
Hope that helps, it got my rusty system in operating condtion
Rick B.
