Hard shift into drive
Old Aug 26, 2009 | 09:48 AM
sstopczy's Avatar
sstopczy
Default Hard shift into drive
I am wondering if it is normal for a '79 to have a pretty hard jerk and the rear end feels like it is getting pressed down a little when I shift into drive. I have the car completely stopped and the brakes fully applied when I shift. It has the original automatic transmission. I did test drive a another one before I purchased this one and it did the same thing, so part of me thinks this is somewhat normal. Your thoughts.....
Old Aug 26, 2009 | 10:09 AM
gerry72's Avatar
gerry72
The rear squat is pretty normal but shouldn't be real prominent. How hard it hits when you go from P or N to drive will depend upon the idle speed (this affects squat, too), and the condition of the pinion support bushing/bracket, though it could be other drivetrain parts as well. This is where taking someone with some C3 experience would be helpful in a pre-purchase inspection.
Old Aug 26, 2009 | 11:40 AM
gofastvette's Avatar
gofastvette
*How hard it hits when you go from P or N to drive will depend upon the idle speed*
. should be around 475-500 for a hydraulic cammed motor.
Old Aug 26, 2009 | 07:43 PM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
Could be the trans mdulator. I had hard shifting while sitting still al gears. D N R P
Installed new mod solved it.
To Hard shift into drive
