crossfire 1982 won't start
Old Aug 28, 2009 | 01:42 PM
autimous's Avatar
autimous
Default crossfire 1982 won't start
It turns over, but does'nt fire up. Newish battery, plugs and wires less than 5k on them. Any ideas?
Old Aug 28, 2009 | 02:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Not firing at all or hit and miss? Got fuel? Have you checked cap and coil?
Old Aug 28, 2009 | 02:44 PM
...Roger...'s Avatar
...Roger...
The 82 s had a habit of lying to you as to how much fuel is in the tank. They stuck 1/2 tank fairly often.
Pull the air cleaner lid off and turn the key on and see if the injectors spray for a second or two.
Old Aug 28, 2009 | 04:08 PM
autimous's Avatar
autimous
I took one of the plugs out and turned it over, the spark was yellow and weak. Now I don't think it was touching anything metal, so I'm not sure if it not being properly grounded would make a difference, but does that mean anything to anyone?
Old Aug 28, 2009 | 05:51 PM
jdp6000's Avatar
jdp6000
Check the fuse beside the battery.
Could be a bad coil/rotor or connection at the distributor.
Jim
Old Aug 28, 2009 | 06:46 PM
autimous's Avatar
autimous
would a bad coil come on overnight, because I drove it last night and it was alright. It's been taking a few seconds to fire up lately when I've been turning it over. Does that support the bad coil theory
Old Aug 28, 2009 | 08:53 PM
autimous's Avatar
autimous
I took the dizzy cap off and removed the coil, and then looked for the fuse in the battery compartment and found a melted 20amp fuse on an orange wire (not sure what that is.)
Long story short, I put it all back together and it fired up straight away. So either the coil needed some breathing space to recollect its thoughts or it was the 20amp fuse. Can any one tell me what that orange wire is responsible for? It's the one that clips to the drivers side inner battery compartment that's fused straight off the battery. I'm thinking that whatever caused it to melt might need looking at!
Thanks for all your input so far
Old Aug 29, 2009 | 11:07 AM
red673's Avatar
red673
Cruising
I had the same problem on my '82..for me it was the ignition module on the cap. Changed that been firing right ever since!
Old Aug 29, 2009 | 06:52 PM
Hootisit's Avatar
Hootisit
On my 82, the fuse in the battery compartment must have got hot, melted, and lost contact. Lossing contact shuts down the ECM, which shut down the fuel pump, engine won't start. This fuse is used to power up the ECM, and used to reset the ECM to remove all codes stored in the ECM when trouble shooting.....
Old Aug 29, 2009 | 07:03 PM
autimous's Avatar
autimous
Thanks Hootisit, I was wondering about that.
To crossfire 1982 won't start
