69 tank sticker decode
Old Aug 28, 2009 | 10:25 PM
crossram's Avatar
crossram
Default 69 tank sticker decode
Top left hand corner. Ident. No.
What is this 6 digit number? It is not the last 6 of the vin.
Old Aug 29, 2009 | 09:00 AM
Alan 71's Avatar
Alan 71
Hi CR,
After the Dealer Order for a Corvette was received by the Chevrolet Central Office it was entered as a Corvette Order in the computer and given an Identity Number for Chevrolet files (abbreviated Ident. No.).
This Identification Number was used by the Central Office for internal purposes to keep track of the order and to identify the vehicle as required through production on the assembly line.
MANY, MANY of the tank sheets I see have that corner cut off.
Regards,
Alan
Old Aug 30, 2009 | 11:22 PM
crossram's Avatar
crossram
Thanks Alan. So the vin never showed up on the tank sticker at all?
Old Aug 31, 2009 | 10:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No prior to 1973, but it did show up on the last two pages of the bundle. The order copy was a 7 page bundle with carbon paper between the pages. Various pages went to different stations on the assembly line. One of these pages became the tank sticker. The last two pages with the VIN went to the station where the window sticker, car shipper, and manufacturer's statment of origin were created.
Upper left corners are often missing because the person bursting the bundle usually held it by the upper left, pulled away the tractor feeds, and burst the bundle.
Most tank stickers have a handwritten penciled number on them which became the job number. After bursting the bundle, the worker checked the last three digits of the VIN, subtracted 500 from it, and jotted down the job number.
Upper left corner torn; penciled job number.
The format of the order (build sheet) changed in '73.
Old Aug 31, 2009 | 03:44 PM
Alan 71's Avatar
Alan 71
Hi CR,
Here's another example of Mike's information... my 71's VIN, 6589... shows 89 in pencil on the tank sheet, same corner missing. The sheet is still glued to the tank. The Job Number, 186, appears a few places on the body in crayon.
Regards,
Alan
Old Aug 31, 2009 | 03:54 PM
halfmoontrail's Avatar
halfmoontrail
The last 4 digits of the VIN are ususally written in regular pencil on the tank sticker (pretty faint), and the last 3 digits (or less 500) are usually written in grease pencil on the tank sticker.
Steve
Old Aug 31, 2009 | 04:20 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Alan 71
...The Job Number, 186, appears a few places on the body in crayon...
And at the top of the sticker in pencil.
The subtract 500 trick works for some years, doesn't work for others.
Old Sep 9, 2009 | 01:20 AM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
[QUOTE=Alan 71;1571309439]Hi CR,
Alan,
I have two Order Copies (one has the left corner cut off and the other is in 3 sections but all the corners are there)
I was wondering what the "398" meant written on the right corner - now I know as the last 3 of my vin are "898"
Great info!
Old Sep 9, 2009 | 01:22 AM
JW3101's Avatar
JW3101
Great info. now I'm beginning to understand the tank sticker info! Thanks for the trick of deducting 500 from the last three of the vin.
To 69 tank sticker decode
