heat barrier
Old Aug 29, 2009 | 04:25 PM
forvicjr's Avatar
forvicjr
Default heat barrier
where do u purchase reflectics,i was told home depot or lowes. where??? as in what department? needing to get car done before carpet install..thanks in advance...
Old Aug 29, 2009 | 04:50 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
it is in the Home roofing and Insulation section. 69VETT
Old Aug 29, 2009 | 05:01 PM
ED79's Avatar
ED79
Bought mine @ Lowes for sure, don't know about Home Depot. Get the sealing tape to seal it all up works great. ED
Old Aug 29, 2009 | 08:39 PM
7T1vette's Avatar
7T1vette
I've only found it at Home Depot...not at Lowe's. Again, at the heating/insulation department. It was made for insulation under crawl spaces and under manufactured homes. Also pick up a can of 3M spray adhesive and a roll of aluminum foil tape (not duct tape) to complete the job. Use just a little spray adhesive to stick the Reflectix down; then cover all joints with the tape. Make sure you get as high up the firewall as you can and under all the components on the tranny hump. That's a big source for cabin heat.
No need to do the storage compartment...at least because of heating problems. No heat there.
Old Aug 30, 2009 | 05:02 PM
forvicjr's Avatar
forvicjr
Thanks for the info, i found it. also purchased the glue and foil tape. it turned out great!!! i insulated to the factory insulation on the firewall is that for enough up???
Old Aug 30, 2009 | 11:07 PM
7T1vette's Avatar
7T1vette
You should be 'good to go'.....
To heat barrier
