Radiator Question
Old Aug 31, 2009 | 03:45 PM
edmccarthy's Avatar
edmccarthy
Default Radiator Question
Hey Guys, I'm doing a frame off on a 1975 coupe. I had to replace the radiator support with a later style, Believe it is an 76L, Went to put in my original radiator last night and found the tank flanges are about an 1" longer and over lap the bottom mounts. The tank mount bottom flanges measure 26 1/2" center to center. I can't for the life of me find a direct replacement. Everything is 27 1/2". Any suggestions.
Thanks,
Ed
Old Aug 31, 2009 | 04:51 PM
SEVNT6's Avatar
SEVNT6
When you say you can't find a direct replacement do you mean the radiator?
The '76 late to '79 rads are 26 1/2" wide, '73 to '76 early are 27 1/2" wide. The two supports & alot of other things changed in late '76....
Old Aug 31, 2009 | 05:41 PM
'75's Avatar
'75
You either need the 75 support or the late 76 radiator.
http://willcoxcorvette.com/product_i...oducts_id=2572
http://willcoxcorvette.com/product_i...ducts_id=24274
Old Sep 1, 2009 | 09:24 AM
edmccarthy's Avatar
edmccarthy
Thanks guys, Got it squared away.
Ed
To Radiator Question
