The link to the "Lars Method" of steering gear adjustment is really the Saginaw Steering Gear/Jim Shea adjustment method. My original steering system papers (including the in-vehicle steering gear adjustment paper) were originally posted and are available in the Steering Section at Terry Rudy's www.corvettefaq.com websight.
Quote:
That's the same link. It's just two clicks up from my link. After clicking on the link above click on the "Jim Shea Articles" and then the steering gear adjustment document and you end up at the same place.
The ORIGINAL directions are in the dealers manual.
These papers refer to manual steering so Power Steering is different?
I believe the ratio is different, but the steering box itself is manual in both cases. Stock C3 power steering has a steering assist piston, separate from the box, unlike the Borgeson unit.
The actual gear box is identical between Corvette power and manual steering systems.
Jim
This is great info.....but would like to pose a question.
Is this the same system and is this applicable to a C4? 1994 model year.
Thank you!
no the c4 had much tighter R&P steering with two optional ratios.
I have 18"x 9.5 tires on my 74 and although the steering seems pretty decent, its when I hit the slightest bump that the car jumps or swerves and scares the crap out of my at times... Im just something is worn out. I have to get it up on ramps or a lift. I made this screw adjustment to my old dodge ram years back and it did wonders there.
Thank you augieDoggy for setting me straight. Sent you a PM as well.
Al
