engine fire 80 vette
Old Sep 2, 2009 | 06:02 PM
cfreelv711's Avatar
cfreelv711
Default engine fire 80 vette
fuel leak lead to fire. damage extensive to engine compartment. all wiring melted except headlight area. hood gone. distributer melted. hoses mostly gone. carb damaged but not melted.vac hoses melted, most damage on pass side,wiper system gone, fender burned thru above tire. minimal damage to fire wall and no interior damage. front of headlights no damage a little scoring on headlight doors.no damage on fenders below hood surround level.windshield shattered.inner fenders seem ok. lip around hood surround seems mostly in tack worth fixing? before almost flawless 38k mile 2 owner car w custom cameleon paint. still flawless from doors back. where to start?? new to forum but long time c3 owner. thanks for advice.
Old Sep 2, 2009 | 06:07 PM
PuddleJumper's Avatar
PuddleJumper
yah its worth fixing if you want to fix it that is otherwise you could sell it to some one who wants an C3 prodject cat (like me or others). but if u sell it u wont get to much for it though.
Old Sep 2, 2009 | 06:09 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
1) PUT OUT THE FIRE !!!
2)Strip everything off that is damaged and make a list as you do it of everything you are going to need.
3) Go to the bank and get 10k out.
4)Take a deep breath and have a beer.
5) Have at it !
Old Sep 2, 2009 | 06:13 PM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
I think he could part it out and still make more money than if he tried to sell the car whole before the fire.....
Old Sep 2, 2009 | 06:15 PM
PuddleJumper
true but i would try to fix it though i mean it sounds fixable to me.
Old Sep 2, 2009 | 07:17 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Let me quess...a rubber hose joining tbe fuel pump to tbe carb...right?
Yes it is worth fixing if you do the majority of the work...if not be ready to spend some $$$$$. You can get the parts new or even find a good usedf ront clip and install it. If you choose to do so and have trouble in finding parts...which I doubt...call me and I will help with the sources I have and try to aid you..
"DUB"
Old Sep 2, 2009 | 07:44 PM
cfreelv711's Avatar
cfreelv711
most remove and replace stuff I can do to save labor, i have done wire harness replace before and pretty straightforward follow color codes, instructions and take time. The main concern for me is the fiberglass. ZERO experience. not sure if I should go with replacement parts or try to fix what is there. I read nightmares on lining parts on body panels. can fiberglass be "rebuilt" successfully and more accurate than replcement parts? I think I would need the hood surround only.. or maybe just fenders, and of course the hood. Body experts..opinion?? What is the path of least resistance?
Old Sep 3, 2009 | 12:31 AM
Goody's Avatar
Goody
I would think the front clip from a donor 80-82 would be the best bet and cheapest route to take. Post some pics so those with body shop experience can give you better advice. Sorry for the misfortune.
Old Sep 3, 2009 | 12:42 AM
okgsds's Avatar
okgsds
wow I am sorry to hear about the fire.. if it happened to my C3 I would just look at it as a fun project to tackle, I love to work in the garage and on my vehicles, some what relaxing if you will. That is until something small gets to me then I spend triple the time it took and should have just walked away for a few instead of cursing the thing all morning (not that this happened to me on replacing the power steering pump or anything ) ..
Of course I might cry a bit first since I just finally after years of dreaming of a C3 got mine.
Old Sep 3, 2009 | 03:47 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 03:49 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 03:52 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 03:59 AM
cfreelv711's Avatar
cfreelv711
removed most wires, hoses and charred pieces. passenger fender real brittle over tire area about 2 ft and "hand size" hole. driver fender similar but smaller area damage. nose all but untouched. i did unfortunatly find firewall damage i could not see before.
Old Sep 3, 2009 | 04:01 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 04:04 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 04:08 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 04:10 AM
cfreelv711's Avatar
cfreelv711
so body shop guys. What do you think? repair or replace..or (gasp)..part out and start over. Thanks for any and all input
To engine fire 80 vette
Old Sep 3, 2009 | 04:30 AM
cfreelv711's Avatar
cfreelv711
Old Sep 3, 2009 | 06:49 AM
BB72's Avatar
BB72
That front clip is toast, literaly. You can't repair that. The bumper might be ok. I would look for a replacement front clip and wiring harness...etc. As long as the firewall isn't too damaged it is salvagable. Maybe some CF guys living around you can give you a hand.
Old Sep 3, 2009 | 06:51 AM
jeff79''s Avatar
jeff79'
St. Jude Donor '10
....ouch!...A new front clip...Once that is off, you can really see what you need to do and have easy access to build from the ground up....The front suspension is probably shot from the heat.....If you have the cash, this is the perfect opportunity to get your engine rebuilt, your suspension redone , and your engine compartment perfected. Use the insurance and kick some cash in ?...That's your call....Good luck ! I feel your pain.
