shakey tac
Old Sep 2, 2009 | 09:10 PM
dgood's Avatar
dgood
Default shakey tac
I have a 1979 L48. When I am cruising down the road the tach sometimes start jumping all over the place from 2500rpm up to 4000+rpms. Not sure why. It is mainly when I am stepping on the gas. I checked the wire going from the dist to the tac and it seems fine. Not sure what it could be. I took the top cover of the dist off and it looks like a big coil there. that is what the tac is connected to. The wires and plugs are new. Any ideas? Thanks.
Old Sep 3, 2009 | 02:24 PM
Shirley1978's Avatar
Shirley1978
make sure the metal part that bolts to the manifold is down tight. when i swapped my motor my tach would jump also and it turned out that it was loose.
Old Sep 3, 2009 | 11:26 PM
SEVNT6's Avatar
SEVNT6
Start here & you might get lucky. I got a bad connection after I painted the intake & didn't scrape the mounting spot clean.....
Old Sep 4, 2009 | 05:18 AM
dgood's Avatar
dgood
no luck with the dist. The bolt was tight. I am going to pull the dash and see if there is a bad/loose wire. It is 30 years old. Thanks.
Old Sep 4, 2009 | 07:09 PM
TODD C's Avatar
TODD C
i have a 79 L 48 and i had a jumpy tach for years. i tried a new tach circuit board and that didnt work, actually made it worse. i wired up a temporary 2nd tach i had laying around and it would jump also. i played around with different coils and modules seeing if that would help, but no luck. a guy at work tried to tell me that something wasnt right with the distributor. finally, i broke down and purchased a new pertronix flame thrower hei distributor and the tach needle was rock steady. i guess something electrical had broken down inside the distributor after 30 years. good luck.
Old Sep 8, 2009 | 10:08 PM
dgood's Avatar
dgood
Todd,
That is the last thing left to try. I just got my new circuit card and it didn't work so off to buy a dist.....
To shakey tac
