Seat back repair
Old Sep 3, 2009 | 12:49 PM
G Littman's Avatar
G Littman
Default Seat back repair
My '81 Corvette has one of the fiberglass seat backs, broken. Can this be re-glued back together?
Old Sep 3, 2009 | 04:34 PM
7T1vette's Avatar
7T1vette
If it is just cracked through (but not broken into two separate pieces), you should be able to put some duct tape on the outer surface to set it in place, then clean surface and add a layer (or 2) of glass/resin to the inside and let it cure. Pull the tape off, clean and dress the surface, and re-color with vinyl dye. If it is broken into two pieces, it's probably easier to find a good used one (then clean-up and re-dye) or just buy a new one.
Old Sep 3, 2009 | 08:21 PM
boatdoc's Avatar
boatdoc
Mack has a used one on ebay right now which seems to be a good deal.
Old Sep 4, 2009 | 01:52 PM
G Littman's Avatar
G Littman
Thank you 7T1vette. Great advise.
G
To Seat back repair
