I coulnd't tell you if it's a common problem or not, but I had the same problem, with no dash lights, but everything else lit up, and a new switch fixed it.
Need more info. What year and did the lights just quit or have they been out for awhile. Looking at my 77 wiring diagram with your light switch to the on position you should have 12 volts to the 5 amp inst light fuse. Check if you are getting voltage down to the fuse first
Design is the same, as wnmech says check the inst fuse for power when the switch is pulled out--check both sides of the fuse for power. might be a 4 amp though--- lower left in your fuse box
I have same problem, still can't figure it out. Tried new switch (autozone, non vacuum), no help. Have power at switch but no power at fuse. However, continuity test with my voltmeter indicates continuity between the switch and the fuse. I gave up on it for awhile but I need to get back to it - especially now that my rear tail lights aren't working but brake lights and turn signals do...
I will watch with interest, but won't get back to this until my DeWitts is in and fans are wired up.
Mine is a '74 btw, and i figured i didn't need the vacuum switch because i have stationary lights.
Your right good move.
On your continuity test. You can't do the cont test with everything hooked up. Remove the the connector at the switch and the inst light fuse. Put one probe on the green wire terminal and the other probe on the right fuse holder contact.
(I would rather see you use a 12v test light)
Can do. I haven't tried it with the fuse out, but I did do it with the connector unplugged from the switch using the green wire. Thanks for the tip - and the corroboration that I can use that switch...
You may have a grounding problem....or the rheostat in the light switch is shot. If you have 12vdc coming out of the switch, it just about has to be a grounding issue. Without a good ground, you really don't have 12 volt across the lights.
Ok it's good that you have 12 volts across the fuse. Next step in my opinion is you are probably going to have to disassemble the dash to first trace the wire from the fuse box to where it goes into the instrument clusters to see if you are getting voltage there. If I remember my tach/speedo cluster share the same ground and my gauges share a different ground but they could tie together in a common place. All the instrument lights should be grey and are grounded once they are plugged into the cluster.
When I first bought the car the gauge lights worked when the headlight switch was pulled out. The dimmer didn't do anything except turn on the lights in the "locked out" position after rotating it.
Then one day they (gauge lights) just didn't come on anymore.
Seems like if the lights, both tach/speedo and gauge cluster, had good grounding points then those probably are still good. Although, maybe I do have that issue.
If your turn signal indicators in the tach and speedo work then they are grounded.
Just checked it. I do have 12v power across the fuse terminals when the switch is pulled out.
Does this mean it's time for a new switch?
No... the switch actually feeds the inst fuse with its power. So if the fuse has power then the switch has done its job.
Did you check the term that the fuse pops into ? Sometimes if the fuse and the terminals are not making a good connection it will fool you. The power comes in the right side fuse contact and goes through the fuse into the left contact and then goes to the dash lights.
So you will all laugh at me, but I replaced the fuse that I thought was fine and the gauges light up now...but...
They only light up when the switch is rotated to the position that is just before "lockout" (lockout being the position that turns the rear compartment light on).
This now makes me think my switch rheostat has failed. So, I think I need a new switch.
Sweet. I was pretty shocked when they came on, mainly because the switch wasn't rotated far enough and I figured I'd give it a spin. I'm glad I did.
Thanks for taking your time to help me everyone. You all are outstanding people, and you do a great service to pass along your knowledge whenever you find the time to.
