76 fuel pump
Old Sep 7, 2009 | 01:16 PM
hogvette76's Avatar
hogvette76
Default 76 fuel pump
I am currently swapping motors. My car has two fuel lines on the fuel pump.I am assuming one is supply and one is a return. My question is the pump on the new block only has one line in. Should I buy a new one with a return or block the return. It is feeding a holley 650 with vacuum secondaries.
Old Sep 7, 2009 | 03:36 PM
HABIT's Avatar
HABIT
Default Search is your Friend . . .
This subject has be discussed in detail somewhat recently . . .
The Search option can give you a Ton of info whether your a new C3 owner or a life long Vette owner.
That being said . . . The decision is up to you as to "how to" or "need to" set up your fuel system for your application. Here are a couple links on the subject by people who seem to be more know knowledgeable than I on this subject. GL
http://forums.corvetteforum.com/c3-t...urn-lines.html
http://forums.corvetteforum.com/c3-t...iguration.html
HABIT . . .
P.S. You get 100% more feedback with PICS . . .
