tach, spedo cable grommets
Old Sep 7, 2009 | 07:21 PM
base1957's Avatar
base1957
Default tach, spedo cable grommets
OK
Cables are already there but the grommets are shot. Do you you have to remove the wires and cables to thread them through the grommets or
do the grommets "seperate" to allow you to place the cables into them.
thanks
Old Sep 7, 2009 | 08:37 PM
cart3113's Avatar
cart3113
Looking at the pictures from Dr. Rebuild the gromments are solid.
Old Sep 7, 2009 | 09:05 PM
base1957's Avatar
base1957
thats what i thought..... dont want to break all that down to run them through..
Old Sep 8, 2009 | 11:34 AM
jr105's Avatar
jr105
I have replaced grommets by cutting one side and sliding the cable into it. If you are concerned about leaks you can seal it with black silicone sealant, but I have never done that. The pressure of being in the hole will hold the grommet together and mine have sealed fine.
Old Sep 8, 2009 | 12:58 PM
markdtn's Avatar
markdtn
You can split them as described above.
Old Sep 8, 2009 | 03:20 PM
Alan 71's Avatar
Alan 71
Hi B57,
I, too, agree with the need to split the grommets.
In fact, even disassembled, the tach and speedo cable connectors, and the back-up light wire connector won't fit through the holes. Just the vacuum lines, and oil pressure line fit the holes.
Regards,
Alan
To tach, spedo cable grommets
