Gear Shift Cable Bracket Location
Old Sep 8, 2009 | 07:25 PM
Oldguard 7's Avatar
Oldguard 7
Default Gear Shift Cable Bracket Location
Is the gear shift cable bracket held to the to the transmission pan with the last two bolts or the middle two? The picture in the AIM does not show exactly which bolts hold it to the pan. If someone can take a pic it is appreciated. Vette is a 79 and has a TH-350 automatic transmission.
Old Jan 26, 2014 | 05:15 PM
AutoFast's Avatar
AutoFast
Default transmission brkt
did you ever get an answer. same concern on 71.
Old Jan 26, 2014 | 05:25 PM
Mooser's Avatar
Mooser
That's a lot of years ago so hopefully he's got it figured out by now.
If yours is a 71 it should be a TH-400
[IMG][/IMG]
M
Old Jan 26, 2014 | 06:10 PM
AutoFast's Avatar
AutoFast
[IMG][/IMG]
M
thank you!
perfect
Old Jan 26, 2014 | 08:59 PM
AutoFast's Avatar
AutoFast
Mooser, I just tried sending a reply and it didn't work so if you get this twice I apologize. I wanted to ask if you have a pic of the position of the lever assy when in park? Also, the back cable that you show in the pic above, where does that lead? When I work my lever from park to the various gears the insulation of this cable actually pushes away from the round metal connector shown in your pic. Does this mean that this cable has to be replaced?
Old Jan 27, 2014 | 07:14 AM
Mooser's Avatar
Mooser
The email system seems to be wonky, not getting notices until the next day etc.
The back cable in the picture (front of trans) goes up to the steering column and controls the steering wheel lock
Here's a couple of other pics that may or may-not help
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
M
Old Jan 30, 2014 | 09:31 PM
AutoFast's Avatar
AutoFast
those are great. One last question and I'll leave you alone. The other end of the cable that goes toward the back of the car. Do you have any pics of that area? I don't know what to call it actually and I couldn't find anything in the other catalogs; perhaps b/c I don't have the correct terminology. Looked in the "build" guide from GM, but doesn't show this detail.
Old Jan 30, 2014 | 09:40 PM
Mooser's Avatar
Mooser
those are great. One last question and I'll leave you alone. The other end of the cable that goes toward the back of the car. ...
Other end of the cable to the back of the car, are we still talking shifter or do you mean the emergency brake cable?
M
Old Jan 30, 2014 | 09:52 PM
Mooser's Avatar
Mooser
E-brake cable
[IMG][/IMG]
[IMG][/IMG]
Or maybe the speedometer cable at the back of the trans, drivers side?
M
Old Jan 31, 2014 | 12:32 PM
Solid LT1's Avatar
Solid LT1
Maybe he's talking about the steering column interlock cable connection from the trans to the steering column base at the firewall?
Old Feb 2, 2014 | 12:22 PM
AutoFast's Avatar
AutoFast
going to work on it today. I'll check. I'm not sure what I'm talking about anymore. Great pics of emergency brake cable though. I've got that part done okay, but I'll use your pics as a QA process.
Thanks. I'll get back to you when I know exactly what I'm asking.
Old Feb 2, 2014 | 01:24 PM
Bakaruda's Avatar
Bakaruda
I'm redoing my E brake, thanks for the pics...
Old Feb 2, 2014 | 10:18 PM
AutoFast's Avatar
AutoFast
E-brake cable
[IMG][/IMG]
[IMG][/IMG]
M
Mooser,
Figured it out; thanks! I was looking at something wrong.
Thanks again!
To Gear Shift Cable Bracket Location
