Zero to 200 and Back! Nice article
To prove this seemingly preposterous notion, we gathered five speed sleds—four tuned cars and one production unit. The severely souped-up entries are a Ford GT, a Dodge Viper, a Chevrolet Corvette Z06, and a Lamborghini Gallardo. The lone production car is the most powerful domestic available, the 750-hp Saleen S7 Twin Turbo.
We knew this competition would be a trip into uncharted territory—particularly the part about stopping from 200 mph—and would require some additional space to perform. So we rented an 11,800-foot airstrip in Oscoda, Michigan, that had once been part of the Wurtsmith U.S. Air Force base. To make sure all the cars were using 93-octane pump fuel, we embarked on a 200-mile, 5000-hp road trip the day before the test to burn off the fuel the cars came with.
After reading the article did you notice the brake rotor failures? Did you notice the smarter team switched to hoosier A6 tires got the best stopping distance? The power to weight ratio was a big factor and you want a rear weight bias. I have 42% front and 58% rear on my 79 Vette
http://comcast.vehix.com/articles/ca...-back/?cid=800
The Corvette had it's issues 1st the engine then the brakes.
What's with those rotors cracking?
A brake failure is not exactly what you want to be dealing with when you're slowing down from 200 Mph.
Could you help me to understand something about front to rear weight distribution and how it effects a C3? I thought 50/50 was ideal to make the car handle "neutral". Wheren't most of the pony cars nose heavy so they understeered because the car manufacturers thought that was safer? I also remember that Zora was thrilled to have the weight distribution on the ZL1 43/57 because that was mid-engine sports car territory (like your own car). So is the idea the more weight on the rear the better the traction but then doesn't that create oversteer (which more often than not gets the novice in trouble)? I know that there are several forum members here (you included of course) that have lots of track experience so you guys know how to deal with it. Is it better to have a car that has more traction at the expense of oversteer or does the C3 chassis lay out remain neutral with tuning (spring rates and sway bar diameters) even though the weight is baised toward the rear? I'm sorry to take this off topic but would like a better understanding of how the weight distribution effects the handling of a C3. Thanks.
Just like you years ago running off the end!!!!!!!!!!!!!
Could you help me to understand something about front to rear weight distribution and how it effects a C3? I thought 50/50 was ideal to make the car handle "neutral". Wheren't most of the pony cars nose heavy so they understeered because the car manufacturers thought that was safer? I also remember that Zora was thrilled to have the weight distribution on the ZL1 43/57 because that was mid-engine sports car territory (like your own car). So is the idea the more weight on the rear the better the traction but then doesn't that create oversteer (which more often than not gets the novice in trouble)? I know that there are several forum members here (you included of course) that have lots of track experience so you guys know how to deal with it. Is it better to have a car that has more traction at the expense of oversteer or does the C3 chassis lay out remain neutral with tuning (spring rates and sway bar diameters) even though the weight is baised toward the rear? I'm sorry to take this off topic but would like a better understanding of how the weight distribution effects the handling of a C3. Thanks.Now look at a drag car or road race car you want max weight x-fer to the rear to put the power down instead of going up in smoke or having the rear hang out like a drifter car.
The whole BS of over steer under steer is just a matter of the best setup. Just watch NASCAR and those guys are driving so much on the edge flat tracking around turns at 180 mph and 1 pound of air pressure makes a difference.
I only get about 3 event days or about sub 6 hours of run time on a set of my slicks.
Any car can change from over or under steer depending on how fast you enter the turn and how much gas petal is applied during the turn.
Just think about it. do the late braking and then turn in with way too much speed the front end pushes. More turn in doesn't help. Punch the gas and now you have 4 wheel drift. Keep it floored and the rear swings out exiting the turn. You just had everything.
I have 335/35 rear tires for the street and most of the time they keep me going straight
Makes perfect sense when you put it that way. I need to get out of the American muscle car mode and start thinking in terms of world class sports cars. Thanks again.
