cigar lighter?
Old Sep 10, 2009 | 09:18 PM
78pace's Avatar
78pace
Default cigar lighter?
Lighter does not work. I just touched a test light to the power wire (orange) and blew the fuse. what does this tell me? Also if need be how do you remove said lighter setup? thank you in advance
Old Sep 11, 2009 | 05:31 AM
78pace's Avatar
78pace
ttt
Old Sep 11, 2009 | 08:59 AM
7T1vette's Avatar
7T1vette
It tells me that the probe you placed on the 'hot' tab at the bottom of the lighter casing slipped and shorted against the housing when you tried to check it.
Old Sep 11, 2009 | 09:03 AM
...Roger...'s Avatar
...Roger...
and you have power and most likely ground.
Now you just have to connect the power and ground through the lighter element to make "fire".
Old Sep 11, 2009 | 09:54 AM
Ganey's Avatar
Ganey
If you have power & ground most likely it needs a new element.
Old Sep 11, 2009 | 10:00 AM
...Roger...
Also if need be how do you remove said lighter setup? (
The outside grounded part of the lighter housing is a big nut,it unscrews from the inner part.
Old Sep 11, 2009 | 04:40 PM
78pace's Avatar
78pace
Thank you all,
I will have at it tonite after dinner
Old Sep 12, 2009 | 06:22 AM
78pace's Avatar
78pace
Ok, replaced lighter unit with one from parts store. Works fine until I plug phone charger into it. Then it blows the fuse. Would be nice to charge phone while cruising in vette but not life or death.
Old Sep 12, 2009 | 09:52 AM
...Roger...
I thought maybe at first the fuse might have been too small but if the lighter works it should be plenty big enough for a phone charger. The socket is meant for the lighter but can be used for charging most of the time but I have seen certain charger plugs that short can short out a lighter socket. You could always install a second charge tap.Also check the bottom of the lighter socket for anything that can short, I've found many things in there including a very small back to a woman's earring.
Old Sep 12, 2009 | 02:39 PM
moosie982's Avatar
moosie982
Dimes and Pennies fit there rather well also
Peace,,,Moosie
To cigar lighter?
