ShiftKit Install HELLLLLLP!
Old Feb 20, 2002 | 05:17 PM
98RKC's Avatar
98RKC
Default ShiftKit Install HELLLLLLP!
I'm sure someone will get right back to me on this....
As seen in the picture, I'm in the middle of the job (well more like the beginning) and although its been awhile since I last attempted this, I don't recall the wires inside the transmission.
I hope this doesn't mean what I think it does. Could I have a 350c ? it's an 81 and hasn't been changed as far as I know. I've had the kit for two months and just worked up the nerve to do the job. Please don't tell me I can't.
[Modified by n8370c, 7:15 PM 2/20/2002]
Old Feb 20, 2002 | 07:42 PM
98RKC's Avatar
98RKC
Default Re: ShiftKit Install HELLLLLLP! (n8370c)
Found the answer while the site was unaccesable so....
Anybody want to buy a B&M shift improver kit. #30262 for GM-68-81 TH 350 & 375B. Only the outer envelope was opened and the instructions have a few fluid stains on the front and back cover. Make an offer:cheers:
Still has the sticker :jester
[Modified by n8370c, 7:46 PM 2/20/2002]
[Modified by n8370c, 10:32 AM 2/21/2002]
Old Feb 21, 2002 | 11:31 AM
98RKC's Avatar
98RKC
another follow up question. It appears that whatever is supposed to be hooked up under the hood that makes this set of wires functional (converter lockup?) is disconnected. It's a four hole plug. If that is the case then will installing the kit for a 350C work properly or mess things up? Should I just use the one I got, for a TH350? :conehead
To ShiftKit Install HELLLLLLP!
