Starting problem
Old Sep 12, 2009 | 06:18 PM
74_Ray's Avatar
74_Ray
Default Starting problem
got a problem. I have just replaced the starter in my 74 was having problems befor with that and now I have a new problem. Every now and then when I go to crank it, it just clicks. Then I have to turn the key again to get it to turn over. Why would it be doing this after replacing with a brand new starter??? Need help.
Old Sep 12, 2009 | 06:20 PM
Jclgodale3's Avatar
Jclgodale3
bad connection? Ground or hot lead. Did you clean the connectors good before reinstalling? Get em good and tight?
Old Sep 12, 2009 | 06:24 PM
BHRIG's Avatar
BHRIG
Make sure your battery is fully charged!!!!
Sounds as if the battery is weak.
Good Luck
Old Sep 12, 2009 | 06:31 PM
74_Ray's Avatar
74_Ray
hmm.... I didn't even think about doing that but your right that maybe it. I'll have to try that and see if that does the trick.
Old Sep 12, 2009 | 06:33 PM
Jclgodale3's Avatar
Jclgodale3
If the problem is random...I wouldn't suspect the battery...but that's just me
Old Sep 12, 2009 | 06:39 PM
74_Ray's Avatar
74_Ray
Yeah I'm gonna have to check the connections the next time I'm under it. I'm hoping it's that and nothing major like wire.
To Starting problem
