All,
just finished the interior restoration yesteday. Went for a ride and everthing was fine. I truned it off and now nothing comes on, no lights, wont start, no guages, complete electrical shutdown.
I tried charging the battery and tested with a meter and shows 12 volts. I read there is a circuit breaker that may have to be reset manualy, (I have 1976 corvette)
Prior to driving I changed the front bezel, shifter face plate, all components removed and put back together. When I started it up and went for a drive, everything worked fine, all guages, lights. etc.
Negative battery ground cable under battery where it attaches to the frame. Do you have 12 volts at the starter solenoid ? Make sure the battery cable connections are clean an actually making connection.
Could be a fusible link
Not sure, I took a meter under the car and tried to get a reading, red meter wire to red cable and not sure if I am supposed to attach to common ground for balck meter wire or a metal such as frame.
Anyway, didnt get any reading with black meter wire to frame.
When your up at the starter put the black meter lead to the frame and red to large term on solenoid -- you need 12 v there.
If you want to check the ground wire coming off your battery and you have jumper cables. Using only one 1/2 of your cable set connect one jumper cable lead to the neg term on the battery and the other end of the same cable to the frame of the car. If car starts the neg cable connection is bad.
Thanks, I tried connecting the jumper to the frame with battery stil connected, thinking maybe I should have taken negative wire off. Anyway, I removed the battery and test across battery post, 12.3v. When I connect battery back up to car, and test across posts, no reading. I remove the negative cable and get a reading
Sounds like a short?
Thank you so far
Thank you so far
Sounds like bad connections. If the neg cable was shorting the battery out enough to draw the voltage down to 0 you would see a lot of smoke. Your conditions you describe are a little weird. To be on the safe side take your battery to Autozone or Advanced and have them test it. At this point if you have a battery that is shorting (disconnecting)internally I don't want you to find that out the hard way. An internal disconnect of one of the terminals could cause a spark and might cause the battery to explode.Let them check it and if its good then we can move on.
Sorry missed that, I had a chev pk up, I whent to turn it over and the battery cable shorted (i assume broke off while turning over), it melted the whole cable and my batt read 0, funny thing is I had my cell pluged into the lighter and the draw from the short drained my cell batery to 0 also, repaired the short (replaced pos batt cable), had to replace starter and batt. I recharged my cell that was fine...
So now I assume when the car was driven it was running on the alt, or there is could be a major draw, or the car was driven on battery power only and the batt is drained to 0, but if there is a reading with the battery disconected and none with the battery conected i think that would constatute a major draw or short
Reason: info wrong
First thanks for the replies to my post. Tomorrow i will take the battery to Autozone and have it tested. Will let you know the results when I have more information.
Please keep the replies coming, need all the help I can get.
Thanks Again, very frustrating.
