headlight switch question
Old Sep 13, 2009 | 05:19 PM
TyCor's Avatar
TyCor
Default headlight switch question
I went turn on the headlights the other night and the lights turn on but they don't go up. I pulled the backup lever which bypasses the switch and they go up and down that way. I always fellt a little resistance whe I pulled the headlight switch out, but now the switch come out easy. I pulled the dash down a little to expose the switch and everything is hooked up right. any ideas?
Old Sep 13, 2009 | 05:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ty,
There is a small metal tab on the headlamp switch that controls the vacuum. You can't see it but when it breaks the switch will not control the vacuum.
Willcox
Old Sep 13, 2009 | 06:56 PM
TyCor's Avatar
TyCor
Willcox,
I have the dash open about 2 inches, so I can see the electrical connections on the switch, I can also see where the two vac hoses hook in...can you explain where the metal tab is? How does the switch come out if I need to replace it? thanks, your advice is always great, you helped me repait my tach last year.
Old Sep 14, 2009 | 02:55 PM
0Willcox Corvette
Former Vendor
Ty,
You have to take the switch apart to see the tab. Here is a picture of a switch exploded.
Yes you'll need to replace the switch to fix it.
68-77 to obtain access to the switch you'll need to pull the LH dash pad loose enough to get to it. I can't tell you to remove switch by removing the three screws on the side.... and pulling the dash pad outward... But some have stated it can be done this way. If I tell you to do it this way and you break the dash pad... You know the drill! However if you take all the dash pad screws loose you should be able to pull the entire pad backwards and get to the switch.
78-82 remove the tach and speedo housing from the dash, (instructions are on our site for this) and you can reach right in to change.
Not shown in the pictures below… On the bottom of the switch is a release button. This button when pushed will release the **** and shaft from the switch. Once you have the **** off you'll see a spanner nut that holds the switch to the dash. Once you remove this nut, you can pull the switch out.
To headlight switch question
