removing parking brake
Old Sep 14, 2009 | 08:21 PM
black15belt's Avatar
black15belt
Default removing parking brake
i'm stuck... trying to remove the parking brakes on my -71...could anyone post a diagram or pictures...a video maybe? it would help alot!! thanks
Old Sep 14, 2009 | 09:06 PM
Jack Wood's Avatar
Jack Wood
Default Here's something I found on this Forum..
http://rowleycorvette.com/corvette_repair.html
It helped me do mine along when used with a healthy dose of patience.
Old Sep 14, 2009 | 09:46 PM
mikep3's Avatar
mikep3
Default Rowley & Zip
The Rowley and Zip are the best, read them, plan a long Saturday and Jack Wood is right, patience, beer & patience.
http://www.corvettemagazine.com/tech...e-rebuild.html
Old Sep 14, 2009 | 11:57 PM
black15belt
thank you! very helpful! also just how hard is it to replace the steel brake line going to the right front wheel?
Old Sep 15, 2009 | 04:04 PM
Alan 71's Avatar
Alan 71
Hi B,
The front cross-over line is relatively easy to replace. Having a/c and p/s make it a bit trickier to get to the line and clips.
The problem often is getting the flare fittings loose without rounding them off. Invest in a GOOD set of flare wrenches!
Regards,
Alan
Old Sep 16, 2009 | 12:06 AM
black15belt
oh.. because my dad said that it would be a chore....he said i may have to remove the radiator...radiator hose...and other stuff like that...hm...ok thanks!!
Old Sep 16, 2009 | 12:48 AM
Peterbuilt's Avatar
Peterbuilt
Default Right front brake line.
Just changed my left front brake line, your 71 should be similar to this.
TIP: Get a master cylinder bleed kit, and loosen the front line on the master cylinder and install the bleed kit, it will keep the M/C from going dry and having to remove and bench bleed it. Then you can remove and replace the line and just bleed both lines on the front. PG.
Old Sep 16, 2009 | 06:18 PM
black15belt
thanks! that's from the AIM right? as far as the bleeding kit it is not neccesary...there hasn't been any fluid in there for at least 15 years.
Old Sep 16, 2009 | 08:49 PM
jnb5101's Avatar
jnb5101
i didn't know that vettes came with "air brakes"!
Old Sep 17, 2009 | 10:18 AM
black15belt
they tried it out on one but figured it would stop faster with normal brakes..LOL
actually the calipers, and master cylinder failed and leaked
To removing parking brake
