Air cleaner for 77
Old Sep 15, 2009 | 11:44 AM
iblive's Avatar
iblive
Default Air cleaner for 77
I may be making rocket science out of this but here goes. Installed a Performer manifold and Holley Spreadbore. As anticipated, the stock air cleaner won't clear hood. Will a 14" drop base clear hood as well as HEI distributor....... or do I just use a size large hammer to make everything fit.
Old Sep 15, 2009 | 01:53 PM
Ganey's Avatar
Ganey
The stock (may not be stock) air cleaner should fit- it will w/ Performer & Q-J. Do you have a spacer(s)? You need a careful check!
Old Sep 15, 2009 | 02:27 PM
Ganey's Avatar
Ganey
If you have the Performer RPM Q-J intake you need at least 1" drop base filter.
RPM w/ 14" drop base about 1", about 3" filter & squarebore Holley fits.
Old Sep 15, 2009 | 04:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i had this set up with a Barry grant speed demon, phenolic spacer and heat shield and a drop base air filter worked just fine
To Air cleaner for 77
