caliper 0 rings
Old Sep 15, 2009 | 08:38 PM
forvicjr's Avatar
forvicjr
Default caliper 0 rings
Ok people im sure this has been asked before, so flame me if you want..I have a set of leaking advance auto brake caliper cores.They were on the car when purchased, I pulled them to buy new o ringed. My ? is should i buy an oring kit for these calipers OR use them as cores and have eklers or some comparable supplier send some out??
Old Sep 15, 2009 | 09:20 PM
...Roger...'s Avatar
...Roger...
Have you opened them up to see whats inside ?
Old Sep 15, 2009 | 09:24 PM
72LS1Vette's Avatar
72LS1Vette
If the calipers are all from Advance they are almost certainly stainless-steel sleeved. Verify that before purchasing rebuild kits, but you should be able to rebuild them with O-ring kits from VB&P. No need to exchange the entire calipers. If you have a lot of $ to burn, send the cores to one of the vendors for some O-ring calipers.
Rick B.
Gordonm's Avatar
Gordonm
Pull them apart, if they are SS sleeved just buy the kit. If not new calipers may be needed.
Old Sep 15, 2009 | 09:31 PM
...Roger...
Make sure the sleeves have been installed correctly, straight,not blocking the holes in the bottom and have a good finish.
edit - also make sure there is no chrome at the bottom of the bore or any where else on the caliper
Old Sep 15, 2009 | 10:03 PM
forvicjr's Avatar
forvicjr
Thanks to all that responded, guess ill takem apart to see what i have. ill see...
Old Sep 21, 2009 | 08:33 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
If you do have sleeved bores, and they are sleeved properly then it is cheaper to go with the O-Ring conversion kits than purchase a reman, and they are easier to install than the lip seals. We've been selling them for $39 per wheel (includes the pistons)
To caliper 0 rings
