Tail light short
Old Sep 16, 2009 | 09:13 PM
Roadie's Avatar
Roadie
5th Gear
Default Tail light short
Hi all,
I have a short in the tail lights.
When I put the fuse in my batt goes dead.
As long as i keep the fuse out it's ok.
Why would there be power to the tail lights with the switch off?
It happend after car stayed out in the rain.
Old Sep 16, 2009 | 09:17 PM
dannyman's Avatar
dannyman
Check sockets for corrosion, then check the wiring for exposed power wire to ground.
Old Sep 16, 2009 | 09:37 PM
Roadie's Avatar
Roadie
5th Gear
Thanks I will check that.
Old Sep 16, 2009 | 09:45 PM
72LS1Vette's Avatar
72LS1Vette
You might have a problem in your steering column also. The wiring for the tail lights runs through the directional switch (why? - ask GM - seemed like a good idea at the time) so if there is a problem with your directional signal switch it can affect your tail lights.
Rick B.
Old Sep 16, 2009 | 10:34 PM
...Roger...'s Avatar
...Roger...
Ok are we talking about the parking taillights or the turn signal taillights ?
Roadie exactly what fuse are you referring to and what year is your car?
Old Sep 16, 2009 | 11:39 PM
Roadie's Avatar
Roadie
5th Gear
1981
And I'm talking about the tail lights, parking lights,
Brake lights are fine.
The fuse is for the tail lights only,thats what the owners manual says
Old Sep 17, 2009 | 12:00 AM
...Roger...
Originally Posted by Roadie
1981
As you said above why would that circuit be active if the parking lights are not turned on and the only thing I can come up with is a bad headlight switch or someone has tapped into the 18 orange wire going from the fuse to the headlight switch. You mentioned rain,if it got into the back of the fuse box or the headlight switch that might be a possibility.
To Tail light short
