Engine guru question?
Old Sep 17, 2009 | 04:52 PM
shamby's Avatar
shamby
Default Engine guru question?
What would make the odd bank 13579 run allot hotter then the even side? The car idles fine, so it's kinda odd to me. Any suggestions on what’s going on I would appreciate. I am getting fire on all pistons.
Old Sep 17, 2009 | 05:33 PM
'75's Avatar
'75
#9 always runs hotter.
Old Sep 17, 2009 | 05:40 PM
shamby's Avatar
shamby
Didn't even think about it being in the carb. I thought I had the timing all screwed up. Thanks
Old Sep 17, 2009 | 05:50 PM
Mike Ward's Avatar
Mike Ward
You have too many cylinders on that side of the engine. Remove one (possibly #9) and keep it as a spare.
If you're measuring temps at idle, the numbers are meaningless. Pay attention to spark plug readings instead. Or just close the hood and stop worrying.
Old Sep 17, 2009 | 06:03 PM
shamby's Avatar
shamby
it's like the even side is not hitting at all. You can touch the headers after running for a few minutes, but the odd side will burn the crap out of you. Temp reading even side 85-100, temp readings odd 150-250. I've done something wrong
Old Sep 17, 2009 | 06:09 PM
Mike Ward's Avatar
Mike Ward
So which is it?
Old Sep 17, 2009 | 06:18 PM
baxsom's Avatar
baxsom
where can i get one of those v10 corvettes ( i am guessing 2468and10) are on the other side
i am guessing that its not the odd side that is the problem
it is supposed to burn you if you touch it.
the fact that you can touch the even side is the problem
Old Sep 17, 2009 | 06:23 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If it were only running on 4 cyls it would idle really rough. What kind of intake manifold are you running? Most 180* intakes have 1 half of the carb supply 2 cyls on 1 side and 2 cyls on the other.
Old Sep 17, 2009 | 06:31 PM
mr.beachcomber's Avatar
mr.beachcomber
Default Check Your Water Jacket Flow
My first inclination is that something is interfering with the water jacket flow on the hot side. (You didn't say how long this has been a problem nor if you made any changes to the engine before you first noticed it, so this is a SWAG.)
I don't think that your carburetor is the source of the problem as a divided plenum intake manifold doesn't feed all the cylinders on the same side. Even with an open plenum intake manifold, it would be difficult to lean out one cylinder head and not the other. (Had plenty of problems w/BBC and stagger jetting in the past to know that usually one or two different cylinders can be too lean, but never the entire side.)
Please keep us in the loop as you tackle the problem. Good Luck!
Old Sep 17, 2009 | 06:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
However I would make sure the idle mixture screws are all turned out the same number of turns
Old Sep 17, 2009 | 06:43 PM
shamby's Avatar
shamby
I'm getting spark on all 8. I've taken every spark plug out just to make sure they are firing. So I'm getting spark but acually no fire. I hope that answers your question Mike. I'm running a Stealth intake and a holley 750. This is a new build and the first time the engine has been started. I've just ordered a new HEI dist so maybe that will help. The engine is bored 30 over edelbrock RPM heads, 1/6 rollers, holley 750, new 8MM plug wires along with plugs and stealth intake. I hope I didn't leave anything out.
Old Sep 17, 2009 | 06:47 PM
wnmech's Avatar
wnmech
Unless I missed it is this a newly overhauled engine? Is the engine actually acting like its only running on 4 cylinders? Have you done a compression check?
Old Sep 17, 2009 | 06:50 PM
Ganey's Avatar
Ganey
350 C.I or 400 C.I. ?
I suppose you adjusted the carb mixture.
Weiand has made a single plane intake w/ a divider that could make one side hotter than the other.
Old Sep 17, 2009 | 06:56 PM
shamby's Avatar
shamby
It's a dual plane and i have not done a compression check, but i will. Yes it is a newly overhauled engine.
thanks for info
Old Sep 17, 2009 | 08:17 PM
Ganey's Avatar
Ganey
Maybe the valve lash was not finalized on one side.
Old Sep 17, 2009 | 08:20 PM
shamby's Avatar
shamby
Ganey, what would it do if I had the timing 180 off. Would or could the car still run?
The engine is a 350
MotorHead's Avatar
MotorHead
The motor idles fine ? How long did you have it running ?
To Engine guru question?
Old Sep 17, 2009 | 08:24 PM
shamby's Avatar
shamby
THe car will idle all day, but I've probably only let it idle for about 10 minutes at a time. How hot do headers normally get at the head?
Old Sep 17, 2009 | 10:17 PM
Imo Apita's Avatar
Imo Apita
I'd go with this one.
Exhaust valves not closing all the way and mixture is burning on the way down the pipe.
High EGT's can be the result of :
  • Lean mixtures
  • Retarded timing
Since it's only one bank I don't think it can be the cam either.
If the cam is installed incorrectly, like a couple of teeth off it would affect both banks.
Old Sep 17, 2009 | 10:27 PM
MotorHead's Avatar
MotorHead
If it's a new motor have you taken it out for spin to see how it runs ? Maybe there's nothing wrong, it hasn't heated up properly yet.
Also you need to seat the rings properly and I don't want to get into a ring seating debate here.
