Engine guru question?
Old Sep 18, 2009 | 01:34 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by Paul Ruggeri
What kind of intake manifold are you running? Most 180* intakes have 1 half of the carb supply 2 cyls on 1 side and 2 cyls on the other.
The stealth is set up like this. Eliminates my post on lean jetting on one side.
Old Sep 18, 2009 | 03:57 AM
73StreetRace's Avatar
73StreetRace
Originally Posted by Mike Ward
You have too many cylinders on that side of the engine. Remove one (possibly #9) and keep it as a spare.
Not enough room in the engine bay for cylinder #9. Maybe in the cockpit ?
Unless it's a Viper engine...
Old Sep 18, 2009 | 04:00 AM
73StreetRace
Originally Posted by shamby
What would make the odd bank 13579 run allot hotter then the even side? The car idles fine, so it's kinda odd to me. Any suggestions on what’s going on I would appreciate. I am getting fire on all pistons.
What part is hotter ? Cylinder head or just exhaust manifold / header ( glowing red ) ?
If you are using a dual plane manifold, maybe some cylinders are richer, and others leaner ( higher temperature )...
Check idle mixture first.
Old Sep 18, 2009 | 07:45 AM
shamby's Avatar
shamby
I'm in the process of doing a resto mod frame off, so all i have is the engine sitting on the frame. It will be awhile before seeing the road. THis weekeng i'm going to readjust the valves again. That has to be where my problem is. It's just the exhaust that is getting hot
Old Sep 18, 2009 | 09:53 AM
73StreetRace
Timing affects exhaust gases temperature a lot. If the mixture is ignited too late ( not enough spark advance ) in the combustion cycle,
it is still burning when the exhaust valve opens, so it produces a lot of heat in the headers...
Old Sep 18, 2009 | 08:31 PM
shamby's Avatar
shamby
I believe I've figured out what might be my problem. I'm only getting 1 to 2 pounds of fuel pressure for some reason so the engine is running extremly lean. The car is also not level with the drivers side a little lower then the passenger side. not sure if that matters, but I starting the think the the even bank is not getting fuel and the reason why the odd side is getting so hot is because it is running so lean. I' ll keep everyone posted
Old Sep 19, 2009 | 01:48 AM
73StreetRace
I hope you didn't melt something inside the engine. A lean condition at WOT caused by fuel starvation can be quickly destructive...
If you're running lean check spark plug colors and condition to confirm. Some of them should be bone white, with maybe signs of overheating, pre-ignition or detonation.
Have a look at this if you want to see what I mean :
http://www.verrill.com/moto/sellingg...colorchart.htm
Old Sep 19, 2009 | 08:01 AM
shamby's Avatar
shamby
I've not really been turning any RPM, nor letting the engine get hot until I figure out what the problem is. I'll pull my plugs and check them out. Thanks again
Old Sep 19, 2009 | 08:22 AM
Ganey's Avatar
Ganey
You need more fuel pressure. Check filter & you can clamp off the return line at pump which can help.
The first time I changed a fuel pump on a Corvette w/ A/C, looked the situation over & pulled the right front tire & used long extensions. Have posted that tip many times. Esp. w/ A/C.
Old Sep 19, 2009 | 12:46 PM
73StreetRace
Between 4 and 7 PSI is the norm for most carbs...
4 PSI at redline is acceptable.
Old Sep 19, 2009 | 01:03 PM
Timsride's Avatar
Timsride
Was there a new cam and lifters installed? If so you need to go through a 20 min breakin period before allowing the engine to idle.2500 to 3000 rpm. Unless it is a roller cam then you don't need a breakin.During breakin each cylinder will get hot at different times but they will all glow red after a few minutes.Make sure its getting fuel first though.
Old Sep 19, 2009 | 02:03 PM
Mike Ward's Avatar
Mike Ward
You can touch the headers after running for a few minutes, but the odd side will burn the crap out of you.
You have one side running cold/dead, not one side running hot.
Old Sep 19, 2009 | 05:22 PM
  #33
Imo Apita's Avatar
Imo Apita
Is it possible the header on the odd side is clogged, or the exhaust is clogged? Birds nest, shop rags?
Old Sep 20, 2009 | 02:19 AM
  #34
73StreetRace
Huum...What else ?
Old Sep 20, 2009 | 11:11 AM
  #35
KB9GKC's Avatar
KB9GKC
Hello,
Check your Heat Riser Valve operation. It creates higher exhaust back pressure to warm up the engine quickly from a cold start.
So it would be normal that the passenger side of the engine would initially be much hotter during warmup. After engine is at operating temps the engine temperature should equalize from side to side. If it does not and the car begins to overheat at idle then expect a stuck or poorly operating Heat Riser Valve.
Hope this helps.
Douglas in Green Bay
Old Sep 20, 2009 | 12:25 PM
  #36
Mike Ward's Avatar
Mike Ward
Originally Posted by KB9GKC
Hello,
This explanation is not correct, besides the fact that the OP has headers.....
The heat riser valve does not create back pressure with the goal of warming the engine faster. It diverts exhaust flow from the passenger side through a passage in the intake manifold under the carburator to join the exhaust flow on the drivers side. This heat warms the intake faster than it otherwise would, allowing the choke to come off sooner. It can also help avoid carb icing when the engine is still cold and the intake temp drops below the dew point.
Further, the passenger side exhaust manifold operates at the same temp as the drivers side as the heat riser valve is downstream of the manifold. This means that only the passenger side exhaust pipe and muffler will remain 'cold' during initial operation after start as most of the engine flow is directed throught the driver's side. This effect is very visible on dual exhaust cars on cold mornings.
A stuck valve will not cause an engine to overheat at idle or while driving but may induce some carb percolation issues in borderline cases.
Old Sep 20, 2009 | 01:04 PM
  #37
shamby's Avatar
shamby
Thanks for all the post and suggestion, but I have not have time to work on the car this weekend. Sick 8 month old no fun. I need to check my valves, my timing (maybe to advanced) and my fuel pressure. I hope to be back in the garage first of the week to get this resolved. I'd say it's something simple that I'm missing.
Scott
To Engine guru question?
Old Sep 20, 2009 | 05:12 PM
  #38
KB9GKC's Avatar
KB9GKC
The valve is allowed to open slowly as the engine warms with a bi-metal spring. That action creates back pressure that allows the warm exhaust flow to be diverted to quickly warm the intake. The majority of people on here are bright enough that detailed explanations are not necessary, thanks for your additional input.
Your right again, I think the majority already undertand this.
This is where your incorrect, with the increased backpressure the passenger side exhaust manifold will warm up to operating temperature quicker than the drivers side. "Watched this action many times with my infrared thermometer." Once the engine is completely warmed the bimetal spring will have opened the heat riser valve entirely, if the heat riser is stuck or doesn't open all the way the exhaust manifold and head will run hotter.
A stuck valve will not cause an engine to overheat at idle or while driving but may induce some carb percolation issues in borderline cases.[/QUOTE]
Maybe not on a cool day if the cooling system can carry all the excess heat away, but on a warm/hot day the cooling system will be overwhelmed and the car will run hot at an idle.
It's important to do your homework on here and don't guess. These are good people on here and they rely on good information to get their cars running right.
If your heat riser has been removed then none of the above really matters until you run into one that is not functioning correctly.
Hope that helps,
Old Sep 20, 2009 | 05:29 PM
  #39
Mike Ward's Avatar
Mike Ward
It's important to do your homework on here and don't guess. These are good people on here and they rely on good information to get their cars running right. [/COLOR]
Yes, that's correct and it represents a culmination of information personally collected over a 30+ year period. I'm not sure how or why you've concluded that explanations of how engine systems work are unnecessary for the users of this forum or why you think you need to moderate.
As I said, 'The heat riser valve does not create back pressure with the goal of warming the engine faster' meaning that the act of passing the exhaust through the intake warms the intake. I did not say that there was no additional back pressure created. No doubt there is, due to the restricted and convoluted path.
I'd like to see an example of a car that overheats at idle due to a stuck heat riser. If true, then cars that have suffered blocked converters would also overheat. At worst, they experience low power/poor acceleration.
Old Sep 27, 2009 | 02:03 PM
  #40
george2066's Avatar
george2066
Default a chevy v8 will run 180 degrees out of time
if you put the timing lite on and you don't see your white marks, check the distrbutor install
