**Never mind the power was not plugged into the 30 amp spot on the Fuse Panel**
I put my windows down several months back and now they will not work any idea on what I can check? I don't see a fuse for them in the general block could there be a fuse somewhere else?
Reason: Fixed Problem
The windows are powered through a circuit breaker. Check your radio fuse because the window relay has to be triggered before the windows get power. The trigger comes from the ACC tap on the fuse box which is fused by the Radio fuse. Thats from memory but I ll check the diagram after I eat.
