Pulsating Pedal
Old Sep 20, 2009 | 09:39 PM
jersey68l36's Avatar
jersey68l36
Default Pulsating Pedal
Seem to have a pulsating pedal, that I'm having a problem trying to figure out. About a year or so ago had 3 leaking calipers replaced and everything was okay at the time that work was done. The following year is when this pulsating issue started.
Looking at all the rotors, nothing seems out of the ordinary, there no scoring on the rotors or chewed up pads or any sort of noticeable distress. Checking the run-out up front, it's at .006 and .007.
Suppose I'll check the run-out out back, but I'm looking for big time run-out. IMO, the run-out that I seeing up front does not point to it being the problem.
Has anyone come across anything like this? the pulsating is very noticable.
Thanks for any response.
Old Sep 20, 2009 | 09:49 PM
Goody's Avatar
Goody
Pulsating brakes are typically caused by brake pad material built up on the rotors.
Old Sep 20, 2009 | 10:32 PM
c3corvette77's Avatar
c3corvette77
it's probably a warped rotor. make sure you use a torque wrench to tighten you wheel lugs as uneven torque can cause warped rotors.
Old Sep 20, 2009 | 11:05 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Agree,..sounds like run-out with at least one rotor.
Old Sep 21, 2009 | 03:24 AM
73StreetRace's Avatar
73StreetRace
That's my opinion, too...
Old Sep 21, 2009 | 08:17 AM
jersey68l36
Thanks for your responses.
As I posted, the front rotors have run-out at .006 and .007.
I'll check the run-out with the rear rotors.
bashcraft's Avatar
bashcraft
This is my problem. It only happens to the left front rotor. Look at it real close and you can see a slight coating on part of the rotor. Some 100grit sand paper takes it right off and it's OK for a while. I'm thinking I need to get a better set of pads.
Old Sep 21, 2009 | 11:53 AM
7T1vette's Avatar
7T1vette
If the rotor has NO runout, the pads will continue to 'smear' on the rotor...even when they are not being applied. You need to have some rotor runout (.002-003") so that the pads will be "pushed" away when they are released from the rotor and not continually rub on them. If this is your case, the pulsations may be from the inconsistent surface condition being created on the rotor with little or no runout (a pad 'grabbing' condition).
Old Sep 21, 2009 | 12:58 PM
Rich's'78's Avatar
Rich's'78
A simple fix is to do a really hard stop from highway speed and then DO NOT SIT with the brakes on until they have cooled (do your stop and then quickly drive on). The pad transfer happens when the rotors are hot and you sit with the brakes on.
Old Sep 21, 2009 | 01:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you may also have a low spot in one of the rotors. did you measure the run out in several places on the rotor or just one?
this is exactly what i had....
Old Sep 23, 2009 | 07:37 AM
jersey68l36
Your right, it has to be some sort of rotor issue. There is just nothing obvious. Pushing back the pads off the rotor, and inspecting with a flashlight, there is nothing out of the ordinary.
Old Sep 23, 2009 | 07:52 AM
bashcraft's Avatar
bashcraft
Sand the rotor surfaces with 100 grit paper and see if it makes any difference.
Old Sep 23, 2009 | 09:37 AM
...Roger...'s Avatar
...Roger...
I have found on 4 piston calipers rotor runout doesn't effect the pedal hardly at all but a rotor with parallelism issues will.
If a rotor is parallel but has runout the fluid push is contained inside the caliper with the pistons on the opposite side compensating for the other side and the fluid in the line going to the master never moves.
Old Sep 24, 2009 | 08:22 AM
bashcraft's Avatar
bashcraft
As I said before, my pedal pulses for a while and then it seems fine for a while. Apparantly the pad material is transferring to the rotor and occasionally it gets wiped clean. I'm using the replacement organic pads. Would a semi-metalic pad eliminate the build up of the pad material?
Old Sep 24, 2009 | 10:06 PM
dannyman's Avatar
dannyman
Drive vehicle with light touch on the steering wheel; and apply the brakes. A front wheel pulsing rotor/caliper will transmit pulse through the steering. Organic pads give the least amount of brake pad failures.
To Pulsating Pedal
