'69 L71 435 Tri-Power Question
Old Sep 21, 2009 | 10:20 AM
Ravine Speed's Avatar
Ravine Speed
Default '69 L71 435 Tri-Power Question
My car drives great. Had the engine rebuilt last winter and it dyno'd at 496 hp and 512 torque.
My question is at what point do the two outside carbs actually begin functioning? Obviously when I pop the throttle they kick in, but for instance, when I'm cruising at 80 mph/3500 rpm, is the middle 2 bbl only feeding the engine until I step on it?
If I was cruising at 100 mph/4500 rpm, would they be feeding the beast?
Old Sep 21, 2009 | 11:19 AM
7T1vette's Avatar
7T1vette
I'm sure some tri-power experts will provide better detail, but the outer carbs are vacuum operated. They will begin to open when the 'signal' vacuum level allows it. There is a specific set-up procedure for adjusting that tri-power setup...I believe that it is in the Chevrolet Chassis Service Manual for your year car. At normal cruise speeds (including legal highway speeds), I doubt that the outer carbs are cracked at all. At 100mph they are likely beginning to open. I much preferred the solid, progressive linkage on a tri-power setup. If adjusted so that the outer carbs wouldn't begin opening until the throttle was at 60% or more, the center 2-bbl would be all that was ever used, unless you were running at elevated speeds or at WOT (when all carbs were fully opened by the throttle linkage).
Old Sep 21, 2009 | 12:14 PM
1ARACE's Avatar
1ARACE
Here's worth printing and reading:
http://www.corvettefaq.com/c3/tripower/
Outboards open dependant on speed and load conditions; via loss of manifold vaccuum which in turn opens outboards.
Mine seems to usually opens up past half throttle.
From experience, if you have a vaccuum leak around the base of the carbs it will not allow them to open properly, if at all, but it would also idle a bit rough.
If you want to check when they are opening and by how much, put a paperclip or similar on the actuator rod on the back of the diaphrams to see how much (if at all) they moved under different conditions.
Old Sep 21, 2009 | 01:23 PM
Ravine Speed
Thanks. This is a nice write-up. It states that under normal driving, the outboard carbs don't open, which is what I figured. It does say that above 4000 rpm, with full throttle, all three are fully open (which is pretty obvious as your a$$ gets mashed into the back of your seat!
This is a good piece of info that all 3X2 guys should have in their files.
Old Sep 21, 2009 | 01:33 PM
Matt Gruber's Avatar
Matt Gruber
imo they should not open at 100 mph steady. if they did, the gas tank would empty pretty quick as they have only power jetting, not cruise. even 120 should be closed, but at some point they will crack open. With an A/F gauge u could see this on the gauge. it would go rich.
Old Sep 21, 2009 | 02:31 PM
...Roger...'s Avatar
...Roger...
I had one come into the shop that was set to open manually when the center went past 1/2 throttle.
Old Sep 21, 2009 | 03:29 PM
Ironcross's Avatar
Ironcross
Probably thats why it was in the shop....manual linkage will not work properly with the Vette tri-powers. Performance would be horrible
Old Sep 21, 2009 | 06:11 PM
...Roger...
Actually it was in for rear bearings and brakes. Driving it reminded me of a misadjusted air valve on a Q-jet , baaawaaaa.
Old Sep 21, 2009 | 06:31 PM
brngrhd's Avatar
brngrhd
really??? i guess i'll take my vette vs your vette and see.... mine is a manual linkage tri-power and it does well....
Old Sep 21, 2009 | 07:15 PM
1ARACE's Avatar
1ARACE
Stock original setup?
Most enthusiasts know the result of over-carburetion--poor engine response, slower acceleration and poorer elapsed times. Holley and Chevrolet engineers point out that trying to supplant the vacuum system with mechanical linkage will probably lead to the problem of over-carburetion.
Quoted via link above...
...so you have an inside scoop above the engineers of Holley and Chevrolet? I'd like to see numbers and proof that it really does to be honest, because if it does I may try it myself.
I for one just don't see how mechanical linkage would do better...please explain more if you could.
Old Sep 21, 2009 | 07:35 PM
brngrhd's Avatar
brngrhd
not saying it would do better as a matter of fact it does have a SMALL bog right off the line but it still blows the tires loose so if you roll into it it does not bog and stays hooked.... not saying it is better just that i did not agree with this statement
"manual linkage will not work properly with the Vette tri-powers. Performance would be horrible"
is it perfect no not even saying that could it be better sure it guess so if it did not have any bog but to say it will not work and performance would be horrible is not true... im doing it now.
Old Sep 21, 2009 | 07:39 PM
brngrhd's Avatar
brngrhd
BTW if i was looking for all out performance and the smoothest drivability i would either go with EFI or run a different intake/carb setup
Old Sep 21, 2009 | 09:45 PM
...Roger...
Wow yours don't appear to be be progressive.
I was going to say if they were progressive wonder if you used center carbs on both ends if the bog would go away ? Tire spin ?
Old Sep 21, 2009 | 09:54 PM
brngrhd's Avatar
brngrhd
yeah it is the center opens about 1/2 way then the outer ones open at 2:1 so they all hit wot at the same time i have thought about changing out the front for a different 500cfm unit to get an extra acc pump but thougth it runs well enough now
Old Jan 28, 2012 | 09:30 PM
Giant10's Avatar
Giant10
I know this is an old thread but it's still pretty interesting.
I dunno...I would assume at 120 mph you are under a pretty severe load with asymmetric increases in aerodynamic friction/rolling resistance which would probably start opening fore and aft carbs.
Old Jan 28, 2012 | 09:41 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Trips aren't as complicated as many would have you believe. Skipping past primary and linkage setup (do ask if you need help there), the 2nds should be setup to begin openning as quickly as is practical for best performance, which is done by installing the weakest secondary diaphragm springs which don't cause bog at WOT under load. Holley kit #20-13, two required. Never try to re-invent the linkage system, and, as always, verify the ignition system is right first before ever attempting to tune a carb.
Old Jan 29, 2012 | 12:38 PM
MMH2009's Avatar
MMH2009
Hey,
I was wondering if you don't mind giving a ball park figure on what you paid for the rebuild? I am thinking of doing it on mine, and was wondering what a ball park going rate is. Now i know there is a ton of variables but id appreciate it.
To '69 L71 435 Tri-Power Question
Old Jan 29, 2012 | 10:56 PM
rponfick's Avatar
rponfick
I agree with Skunkworks. Experiment with the secondary springs. It worked for me. Also, does your engine still have the stock transistorized ignition system, which came on the L71 tripower. They can be fun to tinker with to keep working as designed.
Ralph.
Old Jan 30, 2012 | 09:05 AM
Sir Tripower's Avatar
Sir Tripower
Hi over there!
Living in Germany, I've the opportunity to run my '69 427/400 on unlimited Autobahns sometimes. These are the moments, I can feel the two additional carbs of my Tripower joining the feed-work of my engine. I've made the experience, that the secondaries came in at about 3.500 rpm -what's about 100 mph (3.08 ratio).
I've never tried out the absolute high-speed of my Vette, because I'm afraid of any damage from the engine. Away from this, running with 130 mph at 4.500 rpm (my personal high-score) is good enough for a 40+ old car.
Greets from Germany
Gerrit
Old Jan 30, 2012 | 11:16 AM
Tom454's Avatar
Tom454
The outboard carbs are activated by a port in the bore (venturi) of the center carb. IE- high speed air passing over that port creates a vacuum at the port which is used to operate the vacuum pots on the outboard carbs. Same principle as blowing on the end of a straw draws Jose Cuervo up the straw.
