A freind and I were looking at it the other day and it looks damn near impossible! Has anyone had any expierence doing this project? I really don't want to remove the clutch assembly and the stearing column to do so. Any help would be greatly appreciated!
I am trying to do the same thing right now. I only see 3 too. For once I am proud to be 5-4, plenty of room to move even with the seat in. Let me know the secret if you get them out.
In the firewall there is a plack that has four bolts on it... don't remove it! We did and there isn't anything under there! We thought it'd be a hole or something to get to the 4th bolt but we were wrong. Granted we tried this w/ out a hayes or chilton. So i felt pretty stupid about that move.
You can get a booster/master cylinder combo at Advance Auto for ~$80.00 IIRC. To get the booster off you need a ratchet, deep socket, 2 universals (wrapped with electical tape) and an extension. Make sure you have an assitant handy to provide beer and you might want to practice drinking through a straw while laying in your back. I found that removing the clutch safety switch provided a little more access to the upper nut but that operation presents its own set of challenges.
Rick B.
Did you use their (AA's) setup yourself? Was the pedal pushrod the right length? I know a lot of us (myself included) have run into issues with the pedal rod being too short on replacement boosters. Currently I'm running a booster with a rod that I lengthened with a coupling nut and a bolt with the head sliced off.
Well we did it! It really wasn't that bad. The brake peddle clip was kind of a pain but we got lucky on that deal getting it back on.
Anyways, we got it all together bled all the brakes and the peddle got hard. So i was kind of excited to have brakes again!
But when we started the car the peddle went spungie again and straight to the floor. I don't know what i'm gonna do. Probably run vaccum tests again to see where i'm leaking.
