i am a fan of the demon carb's but to have a duel quad set up they would have to be mounted inline bowls front to back. i dont like the way that looks. is there any way around that or am i going to have to go with a edelbrock setup (witch is just as good)??
Pretty sure the bolt pattern for the Edelbrock carb. is the same for a Holley or a Demon but his problem would be the overall length of the dual quad set up, the Demons and Holleys are longer then the Edelbrock. Dunno how they'd work mounted sideways Ala a tunnel ram set-up, cant remember too much since I hit that tree, Good luck, Peace,,,Moosie
and that got me thinking of how would you would mount them linkage on the front of the carbs. i wanted it to put them on a engine that isnt forced induction
the spread on this special manifold is wider then the traditional dual plane manifolds.
