Removing hood insulation on 76?
Old Sep 23, 2009 | 07:33 PM
63Nova's Avatar
63Nova
Default Removing hood insulation on 76?
Are the pins that hold it in just pull out type? Or is there some sort of special tool I will need? The underhood insulation looks like a cat tore into it and I would just rather get rid of it.
Old Sep 23, 2009 | 07:41 PM
Duke94's Avatar
Duke94
The pins are glued to the bottom of the hood, then a washer pushes on the pin to hold the insulation.
Gary
Here is the ZIP catalog part.
http://www.zip-corvette.com/Zip/prod...FA28F1DFF274F1
Photo of a pin on my 78'.
Old Sep 23, 2009 | 07:54 PM
63Nova's Avatar
63Nova
So how do you safely remove them?
Old Sep 23, 2009 | 08:01 PM
Duke94's Avatar
Duke94
The pins on my 78' are split down the center and spread apart slightly (see photo above) Squeeze the 2 legs together and the washer just pulls off. Do your pins look like this?
Gary
Old Sep 23, 2009 | 08:03 PM
63Nova's Avatar
63Nova
Also I think the pins are different from a 76 and a 78
Old Sep 23, 2009 | 08:04 PM
63Nova's Avatar
63Nova
I guess they are the same, my mistake.
Okay, looks easy enough, just don't have it here right now for reference and was thinking about it.
Old Sep 23, 2009 | 08:09 PM
Duke94's Avatar
Duke94
Yes, I see that now. Here is a page from Doc Rebuild catalog and it looks like yours is a plastic pin with barbs (or it's a "service" replacement). MAYBE if you are careful you can pull the washer back off against the barbs. Also, a little heat from a hair dryer will soften the pin allowing removal of the washer.
Gary
http://docrebuild.com/dr-r-web/8017130.HTML
Old Sep 23, 2009 | 09:29 PM
Duane4238's Avatar
Duane4238
Just a suggestion from experience, but you might want to replace that insulation with new insulation instead of leaving it off. My buddy removed his on a '76 and after a few months of summer driving his hood paint began to fade. Had to have it repainted and then replaced the insulation. It's there for a reason. Good luck!
Old Sep 23, 2009 | 10:51 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
The purpose of the hood insulation is for noise reduction....not necessarily heat. I took mine off 2 years ago and have had no problems with the hood fading, paint bubbling or anything like that. ....and mine's a daily driver in Louisiana's summer heat!!
At the World of Wheels in January 2009
Old Sep 24, 2009 | 12:20 AM
croaker's Avatar
croaker
You don't have one of those glass filters do you I see flames under there
Old Sep 24, 2009 | 09:18 AM
7T1vette's Avatar
7T1vette
The insulation is for both noise and heat build-up in the engine compartment. With the attention to cost reduction and to weight reduction [at that time], GM would have omitted that 'blanket' if they thought it was unnecessary.
To Removing hood insulation on 76?
